Traction control + ABS Warning Lite 2003 Monte Carlo 3.4
Good to know. This morning my abs light and traction light came on for the first time. Brakes seemed to work fine so I drove to work. When I got here and turned the car off, I restarted it and the lights went out. Hoping for a dirty connection at the sensor!
Unless the wheel bearing is noisy, then it is the abs harness. I went to eBay and bought two brand new abs harness($30 each) and the problem is gone. I replaced both hubs with acdelco and still the problem, trust me and replace or clean the harness connectors with electronic cleaner and electrical contact grease. The harness replacement are only a foot or so long but fix the problem and cheaper than a hub.
I had a problem with a '00 grand am years ago, I went through so many bearings before I gave up and let the stealership look at it to tell me it was the harness itself. I think on that particular car I was quoted $400 or so, so I just let the light stay on. I was also in my early twenties during that ownership period so I didn't care.
mwmarshall
May 14, 2022 02:43 AM
Opinion Needed: 2006 monte carlo abs/traction control problem
gburke
Nov 13, 2014 02:11 PM
Chris s
Jan 27, 2013 04:30 PM
3xBlk'monte'ss
Jun 15, 2012 05:36 PM
