6th Gen ('00-'05): tire tread running fast
i have a feeling it has something to do with my alignment, but i think it would be better to replace suspension parts before i get one. right now it seems that my front 2 tires wear pretty fast...im talking like every 3 months....i do get used tires but they do have good tread. i know the sway bar needs to be replaced....possibly the passenger cv axel to. tranny fluid seems to be leaking from that side.What are some other parts to replace to help with that or how do i check if they bad?
Your Sway bar should not need replacing unless you were in an accident. Sway bar End Link Bushings and Maybe you Sway bar bushings should be looked at! Ball joints, tie rods, struts, control arm bushings, these are the components I would look at. With special attention to the bushings. And make sure you use all season tires. Summer, Dry weather, tires will ware faster than all seasons. And at a speed rating that matches or exceeds your normal driving habits.
My tires were wearing real fast, and I am talking in two weeks, and theiy were real good tires. I went to an alighnment shop, and I was told that my strut was bent. I looked myself, and I did not see where it was bent. But I could tell something was wrong, due to the camber being real bad. But I got some kind of kit to make the tire sit more toward, "0". But I still get a lot of road noise. I would check all that was mentioned. And definately get the struts replaced. It is a good possibility that it is just an alighnment issue. I jacked up my car and saw some cracks around the bushings on the suspension. I was just thinking of replacing every componant of my suspension, since the car is getting old.
yea i was deff gonna get a set of quick struts to replace...its weird on the passenger side the bolts that connect the knuckle to the strut are almost oval shaped insted of hex..... i do from time to time suspect that the car was in an accident before tho
I just did all 4 Quick Struts. CompleteStruts.com all 4 for just under $300.
All 4 struts should have Pins with nuts on the end. You need at least a 3 pound sledge hammer to bang then out. The rears are Hard to bang out due to space. And you need a hex driver for the Sway bar bolt. But I don't remember the size. The shape you described for those pins is right.
Front Sway Bars will break. Here is what happened to mine as I replaced it this July 4th weekend.
I did a brake job about a month ago and saw a hole in my sway bar. When I unbolted it, half the flange just fell off.
I replaced the front with "GMPP Kit - Heavy Duty Front Sway Bar w/ bushings and end links" (GM p/n 12498643).... purchased from Summit Racing because of free shipping of $75 order or more. I opted to use Moog front bushings instead (Moog p/n K80815).... purchased from O'Reilly
Also replaced the rear with a GM Grand Prix Comp G Solid Sway Bar (GM p/n 10351314)... purchase from GM Parts Direct
