TIRE SIZES
Old Nov 28, 2006 | 10:41 PM
HaRvArDaLe's Avatar
Default TIRE SIZES
Would 235/50/17s be too small?
Should i just stick with 225/55/17s?
Old Nov 29, 2006 | 09:55 AM
rchurch's Avatar
Default RE: TIRE SIZES
I think they would. I have 255-45-17's and they fit fine. I'm thinking of trying a 275-40, but they might be a liitle big and have some rubbing problems. The height is about the same, but the 275's are almost 1" wider. The 245's rub slightly when I hit a bump, especially with a passenger in the back. The car is also lowered 1 1/2". If your car is not lowered, I would go with at least a 50 for the height.
Old Nov 29, 2006 | 10:35 AM
wiz kidd's Avatar
on google.ca type in tire size calculator and then punch in the 2 sizes and it will tell you all the differences, i dont think you'd notice much difference out of those though
Old Nov 29, 2006 | 12:18 PM
HaRvArDaLe's Avatar
I checked the calculator and the 235/50/17s are .3 inch shorter and the 245/45/17s are .9 inches shorter than the stock 225/60/16s. What should i go with if I plan on getting Eibach lowering springs eventually?
Also, how much would it cost to get my speedometer adjusted?
Old Nov 29, 2006 | 12:26 PM
wiz kidd's Avatar
i wonder if you can do 245 tires?? give it a litte bletter stance with wider tires
BrandonStebing
Sep 16, 2014 09:34 PM
HIxArsenaL
Jul 9, 2013 11:26 AM
DuSSt
Jan 18, 2012 11:41 AM
pitter05
Nov 14, 2007 12:28 PM
old chevy lover
Mar 20, 2007 12:40 PM
