Tighter suspension
Tighter suspension
I want to restore my car to factory feel, or possibly improve it. I'm thinking about these upgrades to get my car back to that perfect new car feel in handling.
heavy duty ball joints - http://www.wbodystore.com/grandprix/...nts-p-274.html
New tie rods - http://www.wbodystore.com/grandprix/...nds-p-257.html
New struts - http://www.zzperformance.com/grand_p...=524&catid=138
Performance sway bars (front and rear) - http://www.zzperformance.com/grand_p...=571&catid=138
New tires - Haven't decided which yet.
Does everything on the list seem okay? Should I lose anything from it? Add something to it? Thanks for the feedback!
Quatermain. I just completed my rebuild for my 02 ss I was tight on money so for now I just got new struts/top plates/bushings complete new lower A arms from GM and outer tie rod ends. along with new sway bar links and bushings.nothing special just went with factory components. I took it for a spin and the front end is like new again. for your list dont forget new strut tower plates and bushings. and dont forget there is outer and inner tie rod ends but most of the time the outers go bad before the inners.
IMO! I thought someone might notice. No, I have not installed anything yet. I have a list assembled of all the parts I'm doing, and the order I'm doing them in. I leave for the Navy in 7 days, once in I will be earning a lot more money and I will be able to afford these modifications. So sometime next year my car will begin to evolve.
I've never seen springs as a stock replacement part for the 6th generation Monte, only as something you use to lower it, and I don't want to lower it. Maybe I'm not looking at everything, but that's what I thought the springs were for.
