Which sway bars?
Which sway bars?
Just wondering which sway bars would be the better choice?
The setup from GM parts direct
http://www.gmpartsdirect.com/results...ber=pk12456148
or the ones from ZZP
http://www.zzperformance.com/grand_p...=571&catid=138
Any thoughts anyone?
http://www.zzperformance.com/grand_p...1049&catid=138
For the front^^
For the front^^
I believe those are the same setups.
The GMPP handling package is the same no matter which vendor is selling it.
Take note that it already came stock on some Monte's.
I forget the production code, but it's something like ST4.
If you have that particular code in the list on your driver side door, then you have the GMPP kit (excluding the strut tower brace that is).
-Riggs.
-Riggs.
ZZP's Strut Tower Brace is different than the GM strut tower brace. I've bought both, and threw away the ZZP STB, IMO the GM STB is better quality, and it does not require the grinding that the ZZP STB does. Plus the ZZP one does not fit well in 7th gens because of the alternator....
-Riggs.
-Riggs.
FE4...that's the code. the 04 intimidator and jr come with also the 05 tony steward.
Darn mine is an FE3. Oh well time to save up some pennies and purchase the GMPP setup as I do not have the STB on my car either.
