6th Gen ('00-'05): Suspension misalignment after strut change
Old Jan 14, 2016 | 10:23 AM
rack's Avatar
Thanks guys,
I will wait for camber bolts to arrive and then will decide what to do, grind the strut or use camber bolts.
Here is picture of my vehicles:
Attached Thumbnails Suspension misalignment after strut change-20150529_195849_resize.jpg
Old Feb 10, 2016 | 11:23 AM
rack's Avatar
Soo...
I got camber adjustment bolts but winter came here and project stalled.
Last days were a little warmer, so I installed camber bolts.
I will be grateful if anyone post factory suspension alignment parameters/degrees in order to compare it with local alignment shop.
I will keep posting the results :-)
Thanks,
Ivo
Old Feb 10, 2016 | 02:43 PM
plumbob's Avatar
Here you go Rack:
WHEEL ALIGNMENT
CHEVROLET MONTE CARLO
Year Model Unnamed Caster Camber Toe-in (in.)
Range (+/- Deg.) Preferred Settings (Deg.) Range (+/- Deg.) Preferred Settings (Deg.)
2004 Monte Carlo F 0.50 +1.80 +0.50 +0.70 0 +/- 0.20
R +0.50 -0.15 0.10 +/- 0.10
2004 CHEVROLET MONTE CARLO SERVICE MANUAL
SEARCH
Suspension Wheel Alignment Specifications
Wheel Alignment Specifications (Front)
Document Preview
Operation
Service Allowable
Service Preferred
Camber – Impala
0.28 to 1.28 Degrees
0.78 Degrees
Camber – Monte Carlo
0.35 to 1.35 Degrees
0.85 Degrees
Caster
2.70 to 3.70 Degrees
Not Adjustable
Steering Angle
3.50 to +3.50 Degrees
0 Degrees
Toe – Total
0.10 to +0.30 D...
Old Feb 13, 2016 | 02:05 AM
rack's Avatar
Thanks Plumbob,
I hope to get aligned next week.
Old Feb 13, 2016 | 08:01 AM
plumbob's Avatar
You're welcome rack.
Happy alignment!
