Strut Bar
Strut Bar
Here is a good web site to get Strut bars or brackets
http://drcustomparts.com/HomePage.htm
I talked with a guy who has the new Impala and he told me he added the front strut bar and a rear strut bar and said it was a good improvement.
Is it easy to add a strut bar to the rear?
RE: Strut Bar
You have to crawl into the trunk (sorta) to get at the rear. Otherwise the strut towers look the same.
There are a few braces around that will fit the montes. IIRC, ZZP used to sell these alum brackets but then started making solid one-piece steel braces. They end up being about the same price when you include the cost of the brace and the brackets.
If you look down at the bottom of the page, there should be links to a bunch of different threads discussing STB's. A search will yeild good results too.
-Riggs
-Riggs
MONTE2000SS
03-08-2012 09:05 AM
