stock rims for 04 Intimidator SS
Old 08-08-2009, 05:21 AM
Botch3's Avatar
Thanks...was wondering what I did to upset the guy??? Will continue to search for original replacement wheels but that looks like it may be a tough mission!! Car is so nice I hate to mess with the original look!!
Old 08-08-2009, 05:27 AM
...It's also on my Search List, and I'm sure several member's will be on the look `out for replacement Rim's for You & will post or PM you `if they find them. Good Luck & Don't Give `Up
Wish you and readers a Happy `Day from `Space : )
Old 08-08-2009, 05:36 AM
CHeck out the below links,
and sometimes `if you call the companies, they might
suggest a place that has what you are looking for...Good Luck
http://www.finishlinewheels.com/CHEVY/MONTE+CARLO/2004/
and
http://www.autopartswarehouse.com/se...=&N=0&Ntt=Rims
Old 08-08-2009, 07:05 PM
Enzo354's Avatar
STILL SLOW
Check ebay, oemwheels or something like that was cheap and they hold up great *knock on wood*
Old 08-08-2009, 09:10 PM
You can also try this site out. They are OEM wheels only. It were I am getting mine.
http://www.oewheelsllc.com/
Hope this helps.
Old 08-22-2013, 06:26 PM
Default Intimidator wheels for sale.
I have an auction up for 4 more days on e-bay for (5) original 2004 Intimidator wheels. They are up for auction because I had the same problem of the insides peeling, yet the outside faces look great. I replaced them on the car with aftermarket alloys for about $125 each.
I did experiment with removing the loose plating and then taking a wire wheel brush via drill to clean the insides up. I then painted them with silver Rustoleum. Cheap fix, works great. Got to watch out for the valve stem area though... if those holes get too bad, then the whole wheel is only good for making a overweight wall clock.
05MonteLS
03-25-2014 09:28 PM
Randdady
03-23-2011 08:16 AM
05MonteLS
12-03-2010 09:00 AM
04superjr
02-09-2009 07:55 PM
mcarloss04
09-21-2005 03:10 AM
Quick Reply: stock rims for 04 Intimidator SS
