SRT Caliber rims on a Monte
I think that charger challenger wheels are 5x115 not 5x114.3. When I look for rims reproductions of the srt rims pop up in 5x115 on ebay. I think only ford uses 5x114.3.
Here is the link and they are real close to the proper backspacing only a quarter of an inch off. Should still fit.
20x9 Replica Charger SRT8 5x115 +20mm Matte Black Wheels Rims Inch 20" | eBay
Even tho they are 20x9 they have a 5.25 inch backspace our cars usually use a 5.5-6 I think they would fit. The .25 less means it sticks out from the mounting point more so it should give extra clearance. It actually should have more clearance then our stock rims. The only thing is you need a tire size to match the current diamter of the tire. I know a 235/50/18 is the exact same width and .1 inches taller then a 235/55/17. If you find the tire to match the stock specs on hieght even tho it is wider the extra clearance should make the 20x9 fit.
235/50/18 is the stock size for the 06/07 Monte Carlo SS. However, put that tire on a 6th Gen and put some weight in the trunk and the tires rub the strut.
Id say we got an extra 2 inches of wheel well we can fill from mounting point befor it became an issue. And by stock I meant the 17s not 16s. so the rim is wider with a diffrent backspace. it would only push it out about 2-2.5 inches.
And Mike wont those fit if you fab up a 1/4-1/2 inch spacer of some sort? The offset on that is only a 1/4" off what fits.
Using a spacer effectively creates more offset so add that 1/2" when determining if the wheel will fit under the wheel well or not.
