Socket size for Front hib replacement ? HELP ,
Hey guys, I'm replacing my front wheel hib/bearings. I seen in a couple of threes that the socket size for the front wheel nut removal is 34 mm.... So, I went out and bought one, that being said... It doesn't fit, to small. Does anyone know the correct size of socket ? Buying one socket at a time stinks to just use 1 time, also gets real expensive when you get the incorrect size. Any help would be great... Thanks...mjclemm...
I bought a 34 mm as well as a 36mm and neither of them are the correct size !..... Unreal..... The 34 doesn't even come close to fitting, way to small... The 36 is to big !.... What gives ? I don't even think they make a 35mm lol.... I need a lil help..... Thanks guys...
