Socket size for Front hib replacement ? HELP ,
Old Apr 26, 2014 | 12:13 PM
MJClemm's Avatar
Default Socket size for Front hib replacement ? HELP ,
Hey guys, I'm replacing my front wheel hib/bearings. I seen in a couple of threes that the socket size for the front wheel nut removal is 34 mm.... So, I went out and bought one, that being said... It doesn't fit, to small. Does anyone know the correct size of socket ? Buying one socket at a time stinks to just use 1 time, also gets real expensive when you get the incorrect size. Any help would be great... Thanks...mjclemm...
Old Apr 28, 2014 | 04:31 PM
MJClemm's Avatar
Thanks.......
Old Apr 28, 2014 | 07:58 PM
Don't remove the packaging, you should be able to test the sizes and then bring back what doesn't fit for a refund.
If 34 was too small, then I would think it has to be 36.
Old Apr 28, 2014 | 11:21 PM
BadSSeed's Avatar
According to my notes it "Should be" a 34MM
Where did you purchase the axle, could be a one of reman unit and the outer joint is different does the diameter of the splines look correct compared to the one thats on the car now?
Old Apr 30, 2014 | 12:01 PM
MJClemm's Avatar
I bought a 34 mm as well as a 36mm and neither of them are the correct size !..... Unreal..... The 34 doesn't even come close to fitting, way to small... The 36 is to big !.... What gives ? I don't even think they make a 35mm lol.... I need a lil help..... Thanks guys...
billmag
Jun 28, 2012 03:35 PM
Cyst3m
Sep 17, 2010 04:08 AM
ltman
Jul 4, 2009 06:52 PM
ChevySSGirl
Feb 22, 2009 08:56 AM
01ss
Aug 24, 2006 12:04 PM
