Rim options
Old Jun 18, 2010 | 08:11 PM
sillykumquat's Avatar
Default Rim options
Can i fit 16x6 rims on my 95 monte? i know stock are 16x6.5 but i cant find any that fits that.
Old Jun 18, 2010 | 08:15 PM
Would i have to change my tires too? I have new tires but need new rims. would my fuzion tires that fit my old rims fit the new ones?
Old Jun 19, 2010 | 12:33 PM
TheMonteMan's Avatar
yeah theyll fit. i wouldnt want to go smaller width on a wheel id want to go larger. and what size tires are you trying to put on there? ive run 185-225 on a 6 inch rim before with no problem.
Old Jun 20, 2010 | 12:49 PM
I found some rims that are 17x7/1/2 which is just too big, i need 16 inchers. The tires are 225/60r16/98h, the width is 6-8. I just dont know if my wheel well can handle more than stock, my wheels now are only about an inch from the mud flaps.
Old Jun 21, 2010 | 11:29 AM
if youre worried about them making contact with the mud flap i have to assume you mean the tread and that would be an overall diameter issue. if thats the case then you should be fine as long as you dont go an inch taller than your current setup. heres a calculator to input your current size and the size youre thinking about and itll give you an ide of how much bigger they are going to be.
http://www.miata.net/garage/tirecalc.html
Old Jun 22, 2010 | 11:08 AM
Ok thanks. Do you think black rims would look cool on my white monte? Or should i just get some subs?
Old Jun 22, 2010 | 04:32 PM
RickAKATed10's Avatar
Photobucket
Depending upon what the wheels look like they'll look good.
Old Jun 23, 2010 | 02:33 AM
Im thinking a 8 or so spoked black gloss rim. Want some black chrome but no can do on that. http://www.thewheelconnection.com/ph...fset=45#222751, like these but a cheaper, junk yard rim. I got my body shop guy looking for some nice rims that we could paint. I just want to make the outside of my monte look a little cooler.
Old Jun 23, 2010 | 11:18 AM
Photobucket
Those are alright. I don't think you'll find anything like that in a junkyard.
Old Jun 23, 2010 | 07:34 PM
monte07's Avatar
its not that big of change it just a sidg type of more rubber for better and safer handling
blackenedSS87
Nov 11, 2007 04:08 PM
Yellow_Monte
Oct 31, 2007 06:59 PM
zipsayain
Apr 13, 2007 11:32 PM
jeffsmonte
Mar 9, 2007 02:29 PM
zipsayain
Feb 26, 2006 01:02 AM
