please look and give advice.
Old Aug 6, 2010 | 08:54 AM
deeboe's Avatar
Default please look and give advice.
thoughts? can i make these rotors clean, i am painting the calipers so i dont care what they look like.
http://cgi.ebay.com/ebaymotors/05-Po...#ht_1113wt_883
Old Aug 6, 2010 | 08:58 AM
How to Clean Rotor from Dirt or Grease. Part of the series: How to Repack Grease & Adjust Wheel Bearing in Cars. Learn how to clean the rotor and outboard ...
www.ehow.com › ... › CarsAuto RepairGeneral Auto Repair - Cached - Similar
  1. $3.98 new
Duplicolor Spray Paints BCP200 Duplicolor Caliper Cleaner Spray Brake $7.88
Brake cleaner spray 500ml Mastercare
  1. Quick/Brake Cleaner removed fat from all engine parts. Ideal for brake discs, motor parts and as preparation for sealing/cold metal sealing...
$4.99 new
  1. Gunk M705 Pro-Series Non-Chlorinated Brake Cleaner - 14 oz.
Hope the above helps
Good Luck
Old Aug 6, 2010 | 09:01 AM
I believe the rotors are just surface rust, should come off very easy.
Old Aug 6, 2010 | 09:06 AM
deeboe's Avatar
chibi, these will fit per our pm conversation right?
Old Aug 6, 2010 | 09:15 AM
I believe they should. I don't see why they wouldn't since you have all the pieces from them. You may want to run stainless steel lines with the kit also.
Old Aug 6, 2010 | 09:25 AM
..Thanks Mod `Mike, for sharing your time & knowledge : )
I keep learning so much from member's + more....
Old Aug 6, 2010 | 10:09 AM
RickAKATed10's Avatar
Photobucket
Damn that's a nice setup. Quite jealous!
Old Aug 6, 2010 | 10:55 AM
silverstreak's Avatar
i would take the rotors and get them turned on a brake lathe at your local parts store if they have a lathe. if not take a right angle grinder to the surface of the rotors
Old Aug 6, 2010 | 01:31 PM
deeboe's Avatar
all right i just bought em. any got any pictures of the on a 06?
Emnasty600
Jul 8, 2011 07:17 PM
nlange
Nov 8, 2009 09:44 PM
kevin187
Mar 17, 2005 01:31 AM
kevin187
Mar 12, 2005 11:16 AM
