7th Gen ('06-'07): Performance Brakes
Old Apr 13, 2015 | 10:45 AM
Slugger088's Avatar
Monte of the Month -- August 2013
The Brembo are a completely different package.
The F-Body upgrade is what other members posted doing (but it's just for slight weight savings, and to get our 00-05 Monte to a dual-piston). You are already at dual-piston calipers so it wouldn't be as big of an upgrade for you.
GXP parts would probably be easier to source, and easier to replace, since they were stock and not just a package developed by an aftermarket company. I would most likely go that route haha
As long as it will be better than stock than I am comfortable going with the GXP brakes. I can't go with the stock rotor size anymore, I do need bigger. I need something better with the bigger wheels.
What would you even consider pairing up with the Brembo set for the rear if you were going to do that option? Thanks again. I need to do this soon so the help is much appreciated.
Old Apr 13, 2015 | 11:00 AM
I truthfully don't know what I would pair for the rear.
I guess the 12" set up and wouldn't look as weird through the rim as the small set.
Link>ZZPerformance - 12" Rear Brake Upgrade kit #ZZ-12BRK-REAR
But, it says it's for 98-03 w-body only, and I don't know where the LS4 fits in that description... lol
Old Apr 13, 2015 | 11:05 AM
Slugger088's Avatar
Yea I saw this. I believe I would need the Brakes off a 2005- 2008 Grand Prix GXP for the rear. I don't think these would work. Not much information online other than 1 on LS1Tech but there is conflicting information there and not 100%.
Old Oct 2, 2015 | 07:44 AM
S.O.G.'s Avatar
Anyone ever find a good set of rotors/pads for the 2006+ ? And by good I mean drilled and slotted rotors lol
Old Oct 2, 2015 | 10:03 AM
Hiroska's Avatar
If I remember correctly the gxp brakes can be used with the stock set up, otherwise find gxp caliper/rotor and bracket drill out the hole a bit and boom. Use solid or vented brakes, the drilled and slotted break easily from what I hear. Have you swapped to solid steel lines?
Old Oct 2, 2015 | 05:48 PM
TheMonteMan's Avatar
ive run the brakeomotive drilled slotted rotters and pads for 5yrs now and havent had them break. i do need pads now though
Old Oct 3, 2015 | 07:33 AM
Hiroska's Avatar
I made the mistake of buying Napa roters and autozone brakes, the golds, now I have a irritating squeek . I'm gonna swap to vented though, I might use the gxp calipers, it's a lot of gxps here and my buddies is crashed, so I'm gonna be trying to steal his
Old Oct 3, 2015 | 10:19 AM
Mels SS's Avatar
I have the brakemotive also.
Old Oct 4, 2015 | 01:08 AM
S.O.G.'s Avatar
Do you guys have a link to those brakes or how much are they?
Old Oct 5, 2015 | 03:14 PM
Hiroska's Avatar
Rock auto just had a clearance sale on brakes, idk if those were on there but I'm gonna do a gxp upgrade soon. It's so many gxps by me it's crazy . If I can find extras I might start selling some lol
