Opinions please!!!
Old Jan 19, 2011 | 10:39 PM
ar3em11's Avatar
5 Year Member1 Year Member
Default Opinions please!!!
I have a 2003 Ls. Im going to go with ssc springs. Now I have to make a rim decision. Would 18s or 20s look/fit better. Id like to fill the gaps as much as possible and id prefer not to roll the fenders.
Old Jan 20, 2011 | 01:46 AM
Enzo354's Avatar
STILL SLOW
Go with 19s. Its a pretty much prefect fit it seems. Unless other members have better luck with other sizes?
Old Jan 20, 2011 | 04:13 AM
ar3em11's Avatar
I have been thinking about it, should i buy rims and tires first, or go with suspension first?
Old Jan 20, 2011 | 09:02 AM
SpinEm_90's Avatar
I say go with the 18s but I've never been a fan of 20+ rims. & that's a rough question. I'm not sure which one I would do first. I'm bout to lower mine but I already have the rims I want so yeahh lol
Old Jan 20, 2011 | 09:08 AM
Really, the 18 or the 20 are going to fill the gap the same way.
When you run a smaller rim, you run more tire width. So overall size stays the same.
Then it becomes a weight and comfort decision more than a looks with the gap decision. Larger rims are heavier as rotational force, which makes it harder to brake and makes it harder for your transmission. It also forces you to run a harder tire since there is less sidewall, and that makes you feel every bump even more.
So I would say a good set of 18s with a decent tire width would be perfect
Old Jan 20, 2011 | 09:30 AM
I agree with mod Mike!
Old Jan 20, 2011 | 10:18 AM
ar3em11's Avatar
I do appreciate the insight. I've seen many mixed reviews on running lowering springs with gr2s....is this a no no? There is a hefty price difference between gr2s and agx's so if I can use gr2s I will but if itsfrowned upon I will just have to wait a lil bit longer to lower.
Old Jan 23, 2011 | 05:17 PM
ar3em11's Avatar
I have chosen to go with 18s and a 235/45 tire. If i choose to lower the car with ssc springs, will i have any rubbing issues? 2003 LS
Old Jan 23, 2011 | 07:40 PM
mrl390's Avatar
You shouldnt have any rubbing issues with the tire size you selected.
shingding88
Jan 22, 2010 03:27 PM
RickAKATed10
Sep 16, 2009 11:16 AM
MAMONTE
Aug 27, 2009 12:17 PM
tjnappy
Aug 19, 2006 06:35 PM
