New rims and tires
Old Jan 14, 2009 | 07:49 PM
Monte SSV's Avatar
Default New rims and tires
My 2007 SS has 235 x 60 tires on 18 x 7 rims. Rims are factory and have a 5 x 115 Bolt Circle with a 52mm offset. Can anyone assist me and tell me how much wider a rim I can use and with whatsize tire is best for that wider rim. I would like to stay with 60 series tires but would like a larger footprint. I want todo all this without spacers and leaving enough clearance to turn in the front and fit inside the rear fender well as wellwithoutrubbing.
Old Jan 14, 2009 | 09:59 PM
inssanity21's Avatar
Default RE: New rims and tires
tomarow night i will see what my tire size is they are from the top of my are 245...... 19 ill fill in the blanks later. hows your engine swaw going?? i have found out that i would have to resleeve it if i was to bore it. wouldnt be worth the power gain. but i got a cam and valvetrain upgrade package coming next month hopefully.
Old Jan 15, 2009 | 07:07 PM
Monte SSV's Avatar
Any help would be appreciated. Dart will have my new block complete at the beginning of next month. I am currently working with a machine shop on transmission parts. I suspect engine build to start in March. Having my dash re-fiberglassed to accept 9 new gauges.4 in the cluster and five in the pad. Researching tires and rims now. Would like to go to larger rims, not much - maybe from the 7" I have to an 8" but I like the stock look but don't know if I can do it. We will see. Thank you.
BlackRainSS
May 26, 2012 05:14 PM
78monteman
Nov 30, 2009 08:40 AM
drephilly
Mar 18, 2008 05:27 PM
motivation2k3
Oct 24, 2007 11:21 AM
