Need pads & rotors with low dust and noise.
Old Feb 28, 2012 | 12:24 AM
NovaSS369's Avatar
Default Need pads & rotors with low dust and noise.
I bought from brakemotive June of 2010 and they lasted a year or so and they are warped to h*** now. I won't buy drilled/slotted anymore since you have a tough time finding someone to grind them down when they get warped. Anyways, I am wanting some input on a good set of front & possibly rear rotors and pads. I don't want to spend a fortune but I do want them to be quiet and not throw a ton of dust. Are the thermo-quiet's any good? Other suggestions?
Old Feb 28, 2012 | 08:08 AM
03SSLE's Avatar
Any time you use a drilled, slotted or drilled/slotted rotor you will see an accelerated increase in wear due to their design. If you want quiet operation and long service life the OE equipment will serve the purpose well. If you go to the aftermarket look at either Raybestos or Bendix.
Old Feb 28, 2012 | 08:44 AM
It seems like it's about 50% as far as drilled and slotted rotors go. Either people have no problem with them or they are junk after a year. I would go with an OEM style rotor and some ceramic pads.
Old Feb 28, 2012 | 08:46 AM
I have heard great things about Blank Centric Rotor replacements, and just throw a decent ceramic pad with them and you should be happy.
Also MAKE SURE your wheels are constantly at the proper torque settings. Improperly torqued wheels can increase your rotor wear.
Old Feb 28, 2012 | 09:35 AM
NovaSS369's Avatar
Really? I have never heard that before. How does that work, how tight should my wheels be?
Old Feb 28, 2012 | 09:49 AM
100 ft/lbs torque.
When you improperly torque a wheel you are putting extra strain on the hub of the rotor, and it might be uneven which aids in warping.
Old Feb 28, 2012 | 11:05 AM
Sparky-88's Avatar
I put Wagner rotors and Wagner Thermoquiet pads (semi-metallic I think) on the front about a year ago. Bought them at O'Reilly Auto. Rotors have a Lifetime warranty; if they ever warp, just take them back to O'Reilly and they hand you new replacements. They offer great stopping power (lots of hills where I live) and fairly low dust. I'm happy with them.
Old Feb 28, 2012 | 07:23 PM
NovaSS369's Avatar
Good to know, thanks for the input.
ultrarevvin1
Vendor for sale section
Jan 14, 2014 10:29 AM
kwalton254
17
Mar 23, 2013 03:22 PM
Slugger088
Sep 29, 2011 08:36 PM
rickyk55
Aug 18, 2008 09:11 PM
BeachBumMike
Aug 21, 2007 11:23 AM
