need help: upgrading brakes and rotars with aftermarket wheels
Old 07-27-2010 | 06:10 PM
deeboe's Avatar
Originally Posted by Mac7504
No, the kit comes with everything new: brackets, rotors, rotor hats, calipers, and lines. But after looking at your Monte, you would have to measure the offset clearance to make sure the calipers would mesh and not hit your rims, though they should be fine with 22's.
exactly. I think the offset is 38..thanks!
Old 07-28-2010 | 08:11 AM
deeboe's Avatar
Yes sir i am serious. could you foward me the part numbers. thanks
Or you can piece together your own Wilwood Brake kit. I can get you part numbers if you really are serious...However, it is pricey. The kit for a 14 inch front rotor (slotted n drilled) w/ a 6 piston caliper, and 13 inch rear (slotted n drilled) w/ 4 piston calipers will set you back $2,500+, not cheap but I can scrub off speed like nothing...And you can’t beat the looks of a damn huge brake kit….
My rotor hats are now black...
84MonteCarloCL
12-26-2013 09:06 AM
Facekicker
10-28-2013 11:10 AM
heavy chevy
09-04-2009 11:06 PM
phoenix_iii
03-22-2006 12:00 PM
Quick Reply: need help: upgrading brakes and rotars with aftermarket wheels
