Need help on a 99 suspension.
Old Mar 2, 2013 | 09:29 PM
Squeegee's Avatar
Default Need help on a 99 suspension.
Its been awhile since Ive posted. Got a few questions about the front suspension/steering. When I make a normal turn, left or right, I can feel a noticeable side to side wobble in the front. I believe to be the tie-rods. Or possibly a lower ball-joint. Also has a noticeable vibration in general. Would either of these cause a rougher ride? Also does the brace that mounts from the strut tower to the core support actually serve a purpose?
Old Mar 3, 2013 | 02:37 AM
A wobble in the front end could be caused by any of the things you mentioned, also you could add the wheel hubs to the list. The best thing to do is jack it up and do an inspection of all the parts to see if anything is badly worn or damaged. The braces you are referring to are there to add structure to the front end and are nothing to do with the suspension.
Old Mar 3, 2013 | 11:28 PM
Squeegee's Avatar
If the hub/bearings are bad, would that assembly wiggle when the front end is in the air?
Old Mar 4, 2013 | 12:05 AM
nitehawkjcb's Avatar
If you can wiggle the wheel with it jacked up then you either have a tie rod problem or a wheel bearing problem.
swanny09
Nov 20, 2013 01:08 PM
tps221
Oct 2, 2013 10:39 AM
X'sMC88
Jul 7, 2013 04:56 PM
ffriccio
Aug 2, 2007 07:29 AM
davesbedroom
May 3, 2007 11:01 AM
