Lowering Springs
I was thinking about that too, 1.7 front and 1.5 rear. Do you have the link or brand as to what they are? They are made from the same cold wounded steel (or whatever it is) that the Sprint Performance Lowering Springs are made out of.
How do you like them? Any troubles? what was the advertised rate and the rate when you actually put them on?
I got the from this buyer on ebay -
eBay My World - dptmotorsport
Below was the description -
GTP W-BODY IMPALA MONTE CARLO SS RED SUSPENSION LOWERING SPRINGS 1.7" DROP RATE
- 100% brand new, Never been tried or installed
- Comes with 2 front and 2 rear lowering springs kit; in Red color exactly shown in the picture
- Better handling stabality/Drift control, Compatible With OEM shock
- Improve Corner Grips and Balance
- Lower Rate: 1.7" Front / 1.5" Rear
- Spring Rate: 450 lbs/in Front 250 lbs/in Rear
- No instructions included, Professional installation is highly recommended
They have been fine so far no issues.
Hey know this thread is a bit old but Have some Spring Questions. I have a 07 LS4 SS with 18" wheels/tires the only 07 monte Eibachs say they are for "V6". I have the PsssssT PsssT sound every time I go over a bump and with 85K on the car bought a set F/R KYB Struts. I was going to Do the Springs at the same Time So I would only have to pay the labor once but I am wondering if their is a difference between V6 and V8 front end spring requrirements. also, seems strange the KYB catalog lists the Rear struts are different from the LS/LT to the SS but the Front struts are the same(seems to me should be the other way around since the weight of the V8 is in the front of the SS).
In Short: Am I going to Get much/is it worth the improvement to go from the Stock V8 SS suspension to the Eibachs? Thanks for your time![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
I have basically the same car as you and I just lowered mine a few months ago. Went with SSC lowering springs and Bilstein struts. So far I love the setup and I can say it is worth doing. The car feels more attached to the road with less body roll, brake dive and squat. There's less torque steer and a bit more grip on the front tires during hard acceleration. Plus it gives the car a great stance.
If you're interested, here's my thread from when I lowered mine: https://montecarloforum.com/forum/ti...istress-37750/
