Lowering Setup
Old Apr 28, 2012 | 01:15 PM
ar3em11's Avatar
5 Year Member1 Year Member
Default Lowering Setup
Its time to lower the monte, so I started with ZZP. They have their drop in combo for 789.99, but I added up if I were to purchase all of the parts individually and do it myself it is 200 dollars cheaper. Does anyone know if there is something I am missing there? Attempted to contact ZZP but havent gotten a response yet.
Side note: My car is an 03 and it only has 50k miles on it. Are the top plates something that i will deffinately have to replace? or will my originals be fine with the low miles?
Thank you in advance!
Old Apr 29, 2012 | 04:01 PM
well with all of the parts individually you will have to compress the strut for the spring, which you would probably have to rent a compressor or have someone do it for you, that will add up to almost the same price.
Old May 8, 2012 | 11:19 AM
davidk67's Avatar
that's bunk.
rental of a spring compressor can't be near $200. check out autozone or a similar auto parts store that has a tool loaner program.
in fact, you can buy your own spring compressor - OTC clamshell variety for about $185 at amazon.
Old May 8, 2012 | 03:28 PM
Franks 03SS's Avatar
2011 Monte Of The Year
i bought autozones spring compressor today for $34 :p
Old May 8, 2012 | 03:30 PM
Originally Posted by davidk67
that's bunk.
idk what bunk means :p
I'm not sure what exactly is included in the ZZP kit, but to do it correctly, you will need correct motor and trans mounts or spacers, also shorter dogbones, etc.
I'll be honest though, when I posted I was condering a good alignment, not thinking that you'd need that either way
Old May 8, 2012 | 04:02 PM
2003L67SS's Avatar
just figured i should chime in here, you will go through CV axles much quicker if you lower the car, but it's just a trade-off like many worthwhile modifications have
Old May 8, 2012 | 04:26 PM
BUDDZZ's Avatar
Just gonna say if you plan on compressing your springs I hope your a handy person who is confidant with there work because once you compress that spring your handling a bomb
Old May 8, 2012 | 04:41 PM
2003L67SS's Avatar
good point, they can seriously hurt or kill you if they come loose at the wrong time
i suggest using a vise grip to hold the spring to the arm on the compressor, the coil can spin itself free if you dont
Old May 8, 2012 | 04:56 PM
the compressors i bought have safety pins on each hook, doubt they would come loose. i took each spring out in like 10 minutes using an impact gun
2003supersport
Aug 14, 2008 03:20 PM
ExplosiveSoundz
Mar 30, 2008 02:41 AM
The Black Machine 29
Mar 9, 2006 01:40 AM
willizm
Feb 4, 2006 05:28 PM
04MonteLS
19
Jun 3, 2005 06:21 PM
