Lowering the Monte
http://www.andysautosport.com/chevro...ering_springs/
there are two brands there. I went with sprint performance springs and im happy with em.
ive heard easy about 5 times in this thread.
i say different. you can rent the spring compressor from autozone for free. i think you give them your id.
its not as "easy" as these guys put it. replacing struts is easy, not the springs. cause when you take those spring compressors off the oem springs and then put the on the lowering springs, they never fit on there right.
a few tips.
take your time. put the car as high as you can take it on stands. put a jack under your bearing. buy a gearwrench for the size that you need for the bolts in the trunk. when replacing the struts always get new mounts, and a front end alignment.
things that make intsall easier
new bellows, insulators, dont think its cool to unscrew the new strut off the car. lol i know everyones done that.
GL idk how it would ride, but if its your fist time, i would do a pair on saturday, then the other on sunday. unless you start at 4 am and have a helper.
it took me 4 hours for my first wheel, then about a half hour for the others.
its a lot of guess work, but all worth the end result.
its true what they say struts are the best thing you will replace on your ride.
a few tips.
After you've done several hundred they become mundane. the "clamshell" style compressor won't give you a hard time with fitment to the new spring, it uses just one screw to turn for the whole compressor instead of 2 or 3 separate hook style compressors which tend to slide around on the spring once under tension.
Absolutely replace the bellows, insulators and top plate & bearing like MAK said, (you'll be kicking yourself later if you don't)
get the anti-pogo washers for the top if you install lowering springs or they'll make noise on the rebound stroke of the strut
Take your time and be careful and you'll really enjoy the fruits of your labor
Aaron
Damn, that seems like alot of work just for lowering your car. I'd thought it'd be a simple as unbolting them and replace with the new lowering springs and strut. (besides the obvious disassembly) Do you really have to align them afterwards?.
Silverbullitt and Goth kid, thanks for the links!
Gothkid, do you have the stock struts on?
I know this is a little late but Im in the process of lowering my 2000, I went with the ssc lowering springs, kyb-gr2 shocks, all new strut plates, new rear trailing arms, new zzp F+R sway bars.... and dont forget about the anti pogo washers and shorter dogbones! There a must! I have not been able to drive the car since I have started, but im sure it will be worth it over stock any day!
Just having to do springs isn't too bad for lowering. For the S10 I had to replace the spindles on the fronts which was a ton more work. I was pleasantly surprised to read the lowering the monte only required springs. Maybe I'll get around to it.
That's just way too much cash. It shouldn't take so much. Shocks/struts and springs, get an alignment and you should be done.
