Low speed wobble since lowering...
Old Oct 28, 2010 | 08:38 PM
Steves Machine's Avatar
Default Low speed wobble since lowering...
Since I lowered the Monte Carlo (2006 LS) I have a wobble in the front as if the lug nuts are loose or the wheels are bent or severly out of balance. This occurs from leaving a dead stop lightly accelerating up to about 15-20mph. I did some seaching and discovered many use a shortened dog bone to eliminate vibrations at higher speeds like 55-60mph. So far mine doesn't seem to have this trouble at high speed just at very low speed. Any ideas?
-Steve
Old Oct 28, 2010 | 10:19 PM
Milhouse's Avatar
Man that sucks bad. I've never had any dealings with lowering a Monte as new as yours so I can't call it but I hope you get it figured out. I'm sure it looks good, now you just gotta make it feel good too, no homo.
Old Nov 2, 2010 | 07:11 PM
Well after driving it for awhile now I realize the wiggle/wobble/vibration is there under acceleration at almost all the time. But most noticable when speeds are lower. Any ideas?
Old Nov 2, 2010 | 09:07 PM
check to see if your tires are balanced or have bald spots would be the first thing i would do
Old Nov 3, 2010 | 08:57 AM
labnjab's Avatar
You may have a tire with a bad chord or one with the tread seperating. Check all your tires carefully, it should be something you can see.
Old Nov 3, 2010 | 10:14 AM
I don't know much about lowering the Monte, but I would think you would require a front end alignment after doing that. If you didn't, I'd have the alignment checked.
Also, you may want to check the wheel bearings for possible problem.
Old Nov 3, 2010 | 11:17 AM
labnjab's Avatar
I forgot about alignment, I assumed it was done. If your caster/camber if off you will get a bad wobble, like a tire is falling off
Old Nov 3, 2010 | 06:14 PM
I never had it aligned after the lowering. It's only under acceleration that the vibrations happen. And its pretty pronounced at full throttle. I would describe it as a wobble at low speed but a vibration at high speeds. I think I'll just put it back to stock.
-Steve
Old Nov 3, 2010 | 08:32 PM
Wilco's Avatar
If you lowered your ride by more than .05 inches you'll need to align it. Eibach spring even sell a kit that allows you to do just that after installing springs. I'm not sure who else sells those kits. But to be safe I'd just take the car to get an alignment.
Old Nov 3, 2010 | 09:23 PM
anytime working with suspension you should align it so even if you put it back to stock you should probably get it aligned, so your best bet would just be getting it aligned as it is, lowered.
