lot's of road noise
Old May 13, 2013 | 12:35 PM
kennydog68's Avatar
Default lot's of road noise
I have a 02 monte carlo s/s we got it used, we knew it had been in a wreck, looked like just sheetmetel damage, sense we have had it, it seams to get louder and louder, sounds like it is road noise from the tires, however we switched rear to the front and it made a small diffrence but the noise is still there, I'v noticed it seams to go away when makeing a right turn, it's NOT a clicking noise, it dosn't do it at low speads ie 0 to 25 or 30, but any faster then that and wow it drives us crazy, also noticed that it seams to have a rough feel to it, like running your hand over a wash board if that makes any sense, please help!
Old May 13, 2013 | 01:20 PM
Probably wheel bearings, those are built into the wheel hub assembly.
Jack the car up, and try to move the tires from left to right and top to bottom with your hands and see if there is any play. When wheel bearings go bad, the tires sound like they are howling.
Old May 15, 2013 | 07:40 AM
kennydog68's Avatar
Ye Ha Did it, both sides needed replaced. 150.00 ea now the wife is happy, that is untell the next problem, found oil leaking while I was fixing the berings, looks like it is comeing from the front main, pasanger side sub frame is soaked on the bottom, that looks like it is going to be a pain to get to, I wish I had a lift it might be easy, oh well. thank you
Old May 15, 2013 | 08:16 AM
Glad I could help
BR549
Mar 30, 2015 09:19 PM
Radagast the White
May 20, 2014 09:41 AM
msnyder1112
Jan 16, 2012 11:09 AM
ronchable2
Aug 29, 2007 02:51 PM
BeachBumMike
Jul 12, 2007 05:58 AM
