loose steering?
hey guys, have not drove my car in like 6 weeks and now that i have it running again, my steering seams loose, like the road really throws me around. so i really need to to get this fixed because i drive for about an hour each way twice a week to go to school. my suspension is stock other than my eibach lowering springs, car has 126k and is all stock as far as i know. i was thinking maybe ball joint or tie rods need replaced? any suggestions?
I had it aligned two days after I lowered it
Did you check tire pressure after the car sat for 6 weeks? The most common causes I see that make a car act the way you describe is improper tire inflation, outer tie rod ends, worn lower control arm bushings or worn struts.
scottyschafer
Dec 14, 2010 03:38 PM
