Klunking noise
Old Jan 20, 2011 | 07:13 PM
cdt785's Avatar
Default Klunking noise
Hi again. Wife says 2004 Monte klunks radomly while driving It has 63K miles on it. Could it be struts? Anyone else have this proble? Thanks in advance.
Old Jan 20, 2011 | 08:50 PM
it could be your intermant shaft on your steering colunm i had mine replaced
Old Jan 21, 2011 | 12:08 AM
Enzo354's Avatar
STILL SLOW
Where is it coming from.
Old Feb 2, 2011 | 06:20 PM
JerryD's Avatar
I realize you said randomly, but is there any commonality? Bumps, turns, straight & level flight? A bad ISS will clunk during turns...
Old Feb 2, 2011 | 07:59 PM
xxtheshockerxx's Avatar
RED DEVIL
my old 03 clunked like crazy before i got rid of it....the mechanics that i had work on it couldnt seem to pin point where i was comming from
Old Feb 2, 2011 | 08:10 PM
Could also be your mounts
Old Feb 15, 2011 | 11:58 PM
99inprogress's Avatar
Probably either strut mounts and/or struts. Did you check the springs? A busted spring can be very annoying let us know, I am interested to see what you find out. Hope for a cheap fix!
Old Feb 16, 2011 | 07:48 AM
cdt785's Avatar
Thank you. I'll check the strut mounts. I just installed new cv joints. The noise still seams to be there. Would I need new struts with 65K miles?
Old Feb 16, 2011 | 08:16 AM
To best give responses, where is the "clunk" or can you isolate it to when it occurs.
I've sometimes tried pushing a car down and release to see if during that motion/bounce a noise re-occurs. One such time (on a '93 Grand Am), I found the linkage between the lower control arm and the sway bar broke and the "clunk" was from those piece banging together).
Old Feb 16, 2011 | 08:35 AM
00SSsupercharged's Avatar
Yep, it could be the mounts. Because, my Monte had the same noise as yours. So I just tightened all the bolts under the hood (medal parts).
I took it to Bell Tire to check it out and they couldn't pint point it.
