Hurst Dazzler Wheels 20x8.5
Old Jan 23, 2013 | 06:25 PM
brewcitymc's Avatar
They will fit but they will stick out, largest offset i found was 32mm & the monte needs a 40- 42mm on a 20x8.5 if they made a set for the awd chrysler lx cars they would be perfect, right offset & 5x115 bolt pattern
where did you find this?
Old Jan 23, 2013 | 06:50 PM
I just looked up 20x8.5 rims that fit the MC on Tirerack & looked at there offsets & compared with cars they make the Hurst wheel for with the same pattern & seen if any were close
Old Jan 25, 2013 | 08:37 PM
Mr Grizzly Mint's Avatar
same thing i do when i look for wheels the fitment guide is not accurate. The monte is not a common car to put mods on so rim companies don't usually list it. Instead do a search for what size you need and it works better. Most rims that will fit and are in the right bolt pattern are not listed as compatible wheels.
volkerc
Dec 28, 2013 07:10 PM
thesnowman20
Dec 8, 2011 10:27 PM
AwesomeSS
Nov 27, 2010 11:48 AM
rcohen
Aug 3, 2007 07:33 AM
