Hurst Dazzler Wheels 20x8.5
Old Jan 22, 2013 | 07:13 PM
brewcitymc's Avatar
Default Hurst Dazzler Wheels 20x8.5
These wheels are beautiful, but can't find any info on offset. Tirerack says will not fit on 7th gen.. .
They come in gold too
Old Jan 22, 2013 | 07:34 PM
I LOVE Hurst wheels but they are sooooo expensive. I don't think they make the offset to fit the Montes - depending on the wheel, they make rims to fit the newer Challengers, Mustangs and Camaros.
Old Jan 22, 2013 | 08:21 PM
brewcitymc's Avatar
If they fit Camaro, you could get an adaptor, kendrels7 put Camaro rims on. I'm not a big fan of adaptors though, adding another potential failure point.
Old Jan 22, 2013 | 08:40 PM
I know of some people being able to fit newer Mustang rims on their Montes - Bullitts seem to be popular for the Montes. But I don't know if they used spacers or not - I'm not a fan of spacers or adapters either.
Old Jan 22, 2013 | 08:51 PM
PacerSS's Avatar
The 6th gens could put Bullit wheels on, there was no spacer required. A lot of wheels came in 114.3 X 5 instead of the 115 X 5. Hubcentric rings helped but weren't necessary. I don't know the bolt pattern of the 7th gens though.
Old Jan 22, 2013 | 09:19 PM
Mr Grizzly Mint's Avatar
If it fits a chrysler 300 it should fit a monte. mikes 300 wheels are 20x9 and fit his monte.
Old Jan 22, 2013 | 11:12 PM
They will fit but they will stick out, largest offset i found was 32mm & the monte needs a 40- 42mm on a 20x8.5 if they made a set for the awd chrysler lx cars they would be perfect, right offset & 5x115 bolt pattern
Old Jan 23, 2013 | 06:46 AM
03SSLE's Avatar
Yep, you'd need to drop down to a 17" rim in order to get 45mm offset.
Old Jan 23, 2013 | 08:00 AM
werewolf-odst's Avatar
I like them in gold, that is really a beautiful wheel.
Old Jan 23, 2013 | 09:09 AM
burgundybullet's Avatar
I'm pretty sure that I have seen a 7th gen with Bullitts. Not sure if he had spacers or not but it will fit the 6th gen for sure. I believe the hubcentric rings were for eliminating vibrations. I got lucky and have no vibrations with mine.
