>How often do you do `it ?<
![Cool](https://montecarloforum.com/forum/images/icons/icon6.gif)
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
Hi `Member's,
It's my understand that your TPMS just informed you that your tires
are at the point of needing inflation.
It does not mean that your vehicle (Monte Carlo) has the
correct tire pressure ?
(the indicated tire pressure on your driver's door frame).
The TPMS only lights `up when it's 25% below the manufacturer's recommended level
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
Tire are Expensive & it pays to take good care
of them & have the correct air pressure for performance, safety, better MPG's & longevity![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
* Please correct me `if I am wrong *
Tire Pressure Monitoring System (TPMS)
What is TPMS?
TPMS, Tire Pressure Monitoring System, is an electronic system that alerts you with a dashboard indicator light when your car's tire pressure falls to the point of needing inflation.
![](http://www.tiresplus.com/images/icon_tpms_dash_icons.jpg)
Why do cars have TPMS?
To help drivers recognize the importance of tire pressure safety and maintenance, Congress passed the TREAD act, which requires most vehicles made in 2006-07 and ALL made thereafter to be TPMS equipped.
How does TPMS work?
How does TPMS work?
There are two different types of systems being used today: Direct TPMS and Indirect TPMS. Direct TPMS uses a sensor that's mounted in the wheel and measures air pressure in each tire. When air pressure drops 25% below the manufacturer's recommended level, the sensor transmits that information to your car's computer system and triggers your dashboard indicator light.
Indirect TPMS works with your car's Antilock Braking System's (ABS) wheel speed sensors. If a tire's pressure is low it will roll at a different wheel speed than the other tires. This information is detected by your car's computer system, which triggers the dashboard indicator light.
What are the benefits of TPMS?
TPMS notifies you when your vehicle's tire pressure is low or is going flat. By helping you maintain proper tire pressure, TPMS can increase your safety on the road by improving your vehicle's handling, decreasing tire wear, reducing braking distance and bettering fuel economy.
Is my vehicle equipped with TPMS?
Your vehicle has TPMS if the "low tire pressure" warning light appears on your dash when the key is turned to the "on" position.
What should I do if my warning indicator comes on?
Check the air pressure in your tires and inflate any tire that is low according to the manufacturer's recommendation. When the tire is at the appropriate pressure, the indicator light should go off. If necessary, replace the tire with your spare tire and see your Tires Plus Total Car Care store for needed repairs or replacement. They'll check your vehicle's tire pressure and perform a systems test on all of your tire sensors to diagnose the problem. Once our technicians address your vehicle's tire needs, they'll then suggest the proper maintenance to get you back on the road.
Why Does Tire Maintenance With Direct TPMS Cost More?
Direct TPMS equipped tires cost slightly more to maintain than non-equipped tires because proper care requires extra parts and labor. The valve service kit, which includes the valve core, cap, nut and o-ring (seal), must always be replaced when a tire is dismounted for service or replacement. A special TPMS tool and additional time are also needed to check and reset the sensor system.
Last edited by Space; 03-10-2014 at 11:37 AM. Reason: I keep making mistake 4-Sure..Just like a human (LOL)
Space i think the TPMS these guys are referring to is in the driver info center. Newer GM cars tell you the tire pressures in the dic.
I always keep an eye on mine visually, if they seem off then i'll put a gauge to them.
BeachBumMike
09-01-2016 07:55 AM
