View Poll Results: How often do you check your air pressure & tires ?
I check & inspect them everyday
16.67%
Once a Week
16.67%
Every two weeks
33.33%
Once a Month
16.67%
I don't know (?) when they look low (?) or someone says something (lol)
16.67%
Voters: 6. You may not vote on this poll
> How often do you check the air pressure in your Tire's ?<>+ More<
Old Sep 10, 2014 | 07:55 AM
Default > How often do you check the air pressure in your Tire's ?<>+ More<
Hi Member's,
How often do you check the air pressure & inspect your Tire's ?
Please vote above & make a post on what you do ? Thanks
Aging Tires
by Pat Goss
A quarter isn’t what it used to be. A quarter is now a penny. Well, at least when it comes to measuring tread depth on tires. See, for many years we’ve been told to take a penny, and we place Lincoln’s head down in the groove of the tire. And if we can see the top of the head, the tire is too worn to use. But, they’ve found that we actually need more tread on a tire to be completely safe. So, the new measurement is using a quarter. We put Washington’s head down in the groove, and if we can see the top of his head, the tire is too worn to use. Now the reason for this is, as tires wear down, they lose their ability to disperse water. And that means that you have a loss of traction on rainy days. So that little bit of extra tread depth means a greater margin of safety. It helps prevent the hydroplaning that is so common.
Now here we have a brand new tire, and we also have a better way to measure tread depth. Instead of using coins, this is a tread depth gauge; it’s about two bucks at the auto parts store. You simply put that down into the tread, and you push it down until it bottoms out, and then you can read the depth of the tread within 1/32 of an inch. Replace a tire at 4/32 of an inch, instead of the old 2/32 of an inch, if you want really good wet traction throughout the life of the tire. Now another big controversy: how old can a tire be and still be safe? Some people say five years, others say six years. Personally, I look toward five years. Now, like this brand new tire that we have here, it’s never been sold, but it’s already eight months old.
Now how do you tell the age of tires on your vehicle? Well, on the side of the tire, stamped into the rubber, is a DOP label. And it is four numbers long. It tells you the week and the year your tire was manufactured. You don’t want to go beyond five or six years. Now certainly, if you’re only driving the car a couple of miles, or at very low speeds back and forth to the store or something like that, it isn’t nearly as critical as if you’re going to get out on the road and travel at high speeds or long distances. But, you know it’s better to be safe than to be sorry for sure. So, follow the rules, and you’ll have a much safer ride. And if you have a question or comment, drop me a line. Right here, at MotorWeek.
Old Sep 10, 2014 | 08:01 AM
What About Winter Tires? (not yet done)
When our instructors, at Advanced Drivers of America, ask each group of trainees "How often do you check your tire pressures?" far more than 90 percent of the answers we get give us cause for concern. Occasionally, somebody will even say: "I never check my tire pressures. I let the shop do it when they service my car." This answer shows a serious lack of understanding about how important and how life-threatening this matter can be. What is is even more bizarre is the fact that even tire companies between them give at least four very different answers to this question and clearly only one of those answers can actually be the safest advice.
Before we get around to doing those periodic tire-pressure checks for safety, however, lets deal with something even more fundamental because first we have to buy good tires!
The first obvious task is to select the correct type of tire for how, when and where you generally drive – such as "all weather" or "off road" – and there's more about that below, but there's another really crucial thing to do at the same time and that is to ask the staff at the tire shop what the age of each new tire actually is, before the tires are fitted to your vehicle!
This might be something you have never even heard about, but many tires actually have the date-of-manufacture printed in the details on the sidewall. (See the photograph, right.)
Member's, do you know how Old your tires are ? The date that they were made ? They claim that tires should not be over 5 years old & some say 6 years old (WoW).... Read below to check how to read the date that your tire was made....
The first two digits of the four-digit number (which is apparently always in a round-ended box) show the week in which the tire was made, so if the first two numbers are "01" it was made in Week 1, and if they are "52" it was made in Week 52 – the final week of the year. The second two digits represent the year in which the tire was made so, for example, "3210" would be Week 32 of year 2010.
The "4808" shows that this tire was made in Week 48 of 2008.
Copyright © 2010, Eddie Wren. All rights reserved.
The danger from buying old tires
The problem, and the potential danger, comes from the fact that as tires age they become weaker and more prone to deflate or even to burst. Even as children we all discovered that after a few days the thin rubber of a balloon starts to perish and air leaks out, and it is the same principle with tires although the thicker rubber lasts quite well for years rather than just days. The question is "how many years" and, according to everything we have read on the subject, the answer always seems to be six. And yet it is not unheard of for unscrupulous stores to sell tires that are five or six years old before they are even pulled out of a vast warehouse to be fitted to some unsuspecting customer's vehicle. The crucial point is that even though those aged tires still look perfectly new when they are bought, the age-related deterioration of the rubber has still taken place and so the only piece of vehicle-equipment that actually keeps your car running under control is in danger of both failing you and killing you. Remember that unless we do high mileages we can reasonably expect new tires to last for two, three or even four years so there is no point whatsoever in buying tires that have less than the necessary number of years remaining before they reach their important and potentially deadly sixth birthday!
What IS the correct pressure to put in your tires?
So now let's go back to the information on the sidewalls of your tires. It is surprising how many people believe this is where one can find out the correct pressure to put into the tires but it is important to read it correctly. What it actually tells us is the maximum pressure at which a tire may ever be used, not the correct pressure for that tire on your particular type of vehicle. (See photograph, left.)
But it is actually the automaker, not the tire maker, which decides the correct pressure for your tires. Why? Because only the automaker can measure the dynamics that their vehicle will apply to the tires and only they that can therefore assess what is needed from the tires, specifically for that vehicle.
Naturally, the pressures decided by the automaker can be found in the drivers' manual, in the glove box, but this information is also to be found on a black and yellow plate on the driver's door post (only visible when the driver's door is open). On European cars, incidentally, the same information is often found on a plate inside the little door that covers the fuel filler cap.
The maximum pressure at which a tire may be used, not the "correct" pressure!
How often should you check your tire pressures?
Surprisingly, tire makers' advice on this important topic seems to have more to do with national culture than it does with any "best practice" or factual pursuit of safety. On the surface of it, that sounds like veiled criticism although it is not really meant to be; culture is an almost inescapable factor in road safety. Yet the sad fact is that at least five major tire makers give us one bit of advice in Europe, an entirely different guideline in North America, and Australia can be different again.
The set periods that are contained in this variable advice are:
  • Once a month;
  • Once every two weeks ("fortnight");
  • Once a week;
  • Every time a car is driven.
In addition, there is also some very valid advice to check tire pressures "before every long journey."
There you have it: at least five different bits of advice. So which one is right in terms of maximum safety?
Well, on the basis that some people make several trips a day in their car, the advice to check "every time the car is driven" could get a bit ridiculous.
At the opposite extreme, "once a month" is seriously inadequate.
The best advice among the remaining options is once a week (with an additional check before any long trip). But if you are a particularly safe person then feel free to check you tire pressures every day.
U.S. National Tire Safety Week
Survey Findings 2010
• Only 17 percent of vehicles had four properly inflated tires.
• 55 percent of vehicles had at least one under inflated tire.
• 15 percent of vehicles had at least one tire under inflated by 8 pounds per square inch (psi).
• 20 percent of vehicles had at least one tire under inflated by 6 psi.
• 31 percent of vehicles had at least one tire under inflated by 4 psi.
Source: Rubber Manufacturers' Association
http://www.rma.org/newsroom/release.cfm?ID=288
The reason that "once a week" is the best, reasonable advice for checking tire pressures is simple: Any form of slow leak from a tire – whether caused by a small nail or perhaps by a bit of grit in the valve – will reduce the pressure by a potentially dangerous degree in much less than a week, let alone a month. So why on earth would we want to risk putting ourselves in a potentially dangerous situation and remaining in that predicament by only checking the pressures once a month?
If all of this seems like a tedious chore be happy about the advent of Tire Pressure Monitoring Systems [TPMS], more and more cars are now fitted with this device. But tires still need to be carefully checked visually, just as often, for signs of damage plus cuts and bulges, any of which can lead to a blow out.
How important is it to have the correct pressure in your tires?
Under-inflated tires wear fast at the edges (a.k.a. the shoulders) of the tread pattern which means you will need new tires sooner. But there's something worse: Under-inflated tires overheat, and overheated tires commonly do burst, and if this happens when you are traveling at speed, the potential for danger is clear.
If, on the other hand, a driver over-inflates the tires it is the central band of the tread pattern that wears fastest because the tire has bulged like an over-inflated balloon. But because the tire is running only on the central band of tread, as opposed to the full width of the tread pattern, there is much less rubber in contact with the road and the result is less grip, especially when grip is most needed: under hard braking. So with over-inflated tires braking ability is reduced.
Tread Depth
The legal limit for tire tread depth in the USA is 3/32" and most people have heard of the trick where a one cent coin is pushed into the groove with the top of Lincoln's head going in first. If the coin goes deep enough for some of Lincoln's hair to be hidden from view, the tire is legal but if all of the hair remains visible the tread is too worn and the tire is illegal.
And if the tires on your Mercedes or your Cadillac start to look like this, it
might be time to get new ones! (Photo copyright © 2010, Eddie Wren)
If, however, you often drive on very wet roads (think "Florida thunderstorms every afternoon in summer") or if winter is approaching and you may end up driving on soft or wet snow, 3/32" of tread is definitely not adequate for safety. Remember that the key purpose of tread is to provide channels through which water on the road can escape from under the tire and therefore let the tire grip better. Changing your tires sooner than you normally would may make you feel as though you are wasting money but that "additional cost" is a joke when compared to the value of your life and the lives of your loved ones.
Old Sep 10, 2014 | 08:34 AM
I definitely check my tire pressures every other week. I also check the oil in the Monte at that interval.
And any drive that is over 2 hours, I will do another check
I use this tire pressure gauge:
Tire Pressure Gauge - Amazon Tire Pressure Gauge - Amazon
It's been one of the best ones that I have owned.
Old Sep 10, 2014 | 08:38 AM
Thanks Admin `Mike,
I hope your words/post inspire others to do the same
A good tire gauge is a great investment 4-Sure
Robot Check Robot Check
Customers Who Bought This Item Also Bought
Page 1 of 20
Start over Start over
Back Back
Old Sep 10, 2014 | 09:55 AM
turbo monte's Avatar
I check mine before pulling her out of the garage since she sits a lot.
Old Sep 10, 2014 | 10:07 AM
Habbibie's Avatar
Once a year lol.
Also check pressure in the spare tire, I checked mine recently and it was a good 30 psi below. Would suck having a flat spare tire when it's ever needed.
Old Sep 10, 2014 | 10:36 AM
MAMONTE's Avatar
I check mine about once a month. Although, I check more often until I "learn" the tires. The tires I has on the Monte before recently changing them leaked virtually nothing, so once a month was plenty and usually they needed no air.
So far, I've check the new tires twice and they aren't loosing anything either. So I'm going with monthly on these too.
BeachBumMike
Sep 1, 2016 07:55 AM
Jun 29, 2012 10:51 AM
Jun 28, 2012 08:55 AM
May 21, 2009 03:35 PM
May 20, 2009 01:44 AM
