HELP! Rec tire size?
1983 monte...
Okay. So ive decided that i want to run a 255/60r15 on the rear on a 15x8 rim. but my trouble comes with the front... i want to run a 15x4.5 rim. WHAT SIZE TIRE SHOULD I USE?
Also...what is the stock backspacing for stock 15 inch monte carlo rims?
I hope the below helps > Time to do more searching..Check back to see what our member's post > Good Luck
- Tires & Wheels - Monte Carlo SS Information & Resources
www.montecarloss.com/SSThunder/tires.html
Monte Carlo SS's were factory equipped with P215/65R15 Raised White letter ... '86/'88 SS wheels had a 3mm negative offset and had 3 3/4" of rear backspacing. ...Code Scheme: W-D Example: 8.25-15 W - Tire section width (inches) (ex: ...
- Actual dimensions of "stock" Monte Rallye wheels - First ...
www.firstgenmc.com › Forums › Technical › Suspension Tech
Jul 6, 2010 - 9 posts
So I measured one of my "stock" Rallye rims today and was surprised to find ... 15" Chevy Rallye wheels are either 15X7 with 3.5" backspace (for ... wheel narrows or widens it sucks in or widens the sidewall 2/16" of an inch.Max wide tire size - First Generation Monte Carlo Club ...
Feb 4, 2010
1970 2" drop spindles and tire size? - First Generation ...
Dec 6, 2009
Wheel and Tire data base.
Mar 22, 2009
More results from www.firstgenmc.com
- HELP! Rec tire size? - Monte Carlo Forum - Monte Carlo Enthusiast ...
montecarloforum.com › ... › Your Ride › Tires & Rims & Suspension
26 mins ago - 1983 monte. ... that i want to run a 255/60r15 on the rear on a 15x8 rim. but my trouble comes with the front... i want to run a. ... Monte Carlo Forums ...Also...what is the stock backspacing for stock 15 inch monte carlo rims?fourth gen offsets and back spacing - Monte Carlo Forum ...
1 post
Aug 3, 2010
G Body Rear Tire Size?
Oct 7, 2006
More results from montecarloforum.com
- Stock rims - ChevyTalk --The Social Network for Chevy Fans
www.chevytalk.org › ... › Chevelle-Beaumont › 1973-1977 Chevelles
May 8, 2013 - 16 posts - 8 authors
Remind me, what is the stock rim tire configuration> ... Then again, I recall they were 14 inch rims. ... 80's Camaro or Firebird, 80's Monte Carlo, Cutlass, Grand Prix. ...The original Rally wheels on Malibus are 15x7 with 4-1/4" backspace, which were used on many of these G3 Chevelles(and Monte Carlo).
- Monte Carlo: tire and wheel info - darklair
www.darklair.com/monte/tires.html
It is important to note the stock bolt pattern as well, it is "5 on 4 3/4". ... 235/60 on 15x7(offset: 6mm); 235/55 on 16x8 (4" backspacing); 245/50 on 16x8 (4" backspacing) ...personal favorite and what I run on my SS using 4 16x8 f-body front wheels. ... Speed at 1800 RPM with 3.73 rear, 26.00 inch tires and 0.67 top gear: 55 ...
- What wheels/tire do you have? [Archive] - Chevelle Tech
www.chevelles.com › Chevelle Tech › Mechanical › Wheels & Tires
Nov 9, 2004 - 36 posts - 31 authors
15X7 Rally Wheels (mid-70's Monte Carlo) Don't remember BackSpacing (but stock).... 15X8 Ralley (custom offset from Wheel Vintiques) ... Car was lowered 3-4+ inchesall around with only minor tire clearance problems ...
- Need Wheel Help • GBodyForum.com - 1978-1988 GM G-Body Cars ...
gbodyforum.com › ... › Chassis / Drivetrain / Suspension / Wheels
Jan 15, 2012 - 5 posts - 2 authors
Can I run a 10" wide tire and rim on a stock 1986 monte carlo ss? 2. ... push it to 4.5"backspacing, with 50 series tires mounted on a 15 or 16 wheel. .... So if i run a 17 or 18inch wide wheel I will need a 4.5" backspacing with a ...
- Backspacing and Offset • GBodyForum.com - 1978-1988 GM G-Body Cars ...
Jul 7, 2008 - 15 posts - 9 authors
Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, ... For instance .. if you have two 15x8 rims with a 5 inch B.S. will the offset on both .... Im looking into this also, What is the Stock BS for a Monte car anyway?
- QUESTION FOR THE G-BODY GUYS - Yellow Bullet Forums
www.yellowbullet.com › ... › Fire your bullets!!! › Trash Or Be Trashed
Nov 24, 2010 - 15 posts - 10 authors
What size tire are you guys fitting under a stock suspension car no tubs? Wheel width?offset? ... I put a 275/60 radial on my Monte with a bit of hammering. 15x8 with 4.5bs I believe. 1987 Monte Carlo SS - 2006 GXP ... 275/60 on a ten inch rim 5.5 backspacewill fit on an 83 cutlass and look good. You could ...
- Chevrolet Factory OEM Steel Wheels - Wheels and Caps
www.wheelsandcaps.com/c-2285-factory-oem-steel-wheels_chevrolet.aspx
We specialize in replacement factory OEM steel wheels, replica steel wheels and used steel wheels for most Chevrolet wheels. ... Monte Carlo Factory OEM SteelWheels ... Transwheel Steel Wheel, Rim 15x6, 5x5 Bolt Pattern, 4 Slot - 1613.
