to good to be true?
Old Jun 15, 2010 | 01:25 AM
recci03's Avatar
Default to good to be true?
well i've been looking to lower my car more, but haven't found exactly what i wanted. i stumbled across some coilovers on ebay, but they seem a little sketchy.
http://cgi.ebay.com/ebaymotors/00-01...#ht_1801wt_829
if not those, does anyone know of a writeup on how to make your own? any advice would be awesome. thanks guys.
Old Jun 15, 2010 | 05:14 AM
It seems doubtful, but if lowering your car cheap is what you want, I would buy those. You can't knock the price. And it wouls be less permemant or "terminal" then chopping your springs. Which I have done before on my old 87 LeSabre. You just take off the strut, unload the coil, and cut a couple of rings off. Make sure the cut ends where it seated before. This isn't a great idea because you won't know the ride heaight until you put it back together, and then you can't do anything about it. Alignment will likely be out, but everything seemed fine with the LeSabre when I did it
Old Jun 16, 2010 | 10:34 AM
Slo-Ridez LTZ's Avatar
they will work but let me let you in on a little secret....those are the same coilovers used on HONDA CIVIC'S so welcome to the honda bounce also if your gonna do this just buy the honda ones there usually green or blue and $50 cheaper....all in all the same thing
http://cgi.ebay.com/ebaymotors/1996-...item2a07b8d9a6
see what i mean
Old Jun 18, 2010 | 05:33 PM
bob442's Avatar
civics bounce because they weigh 2400lbs wet, and have a very small wheel base, a montecarlo weighing over 1000lbs more, and a wheel base of what, 30" or more? would ride different than a civic, but thats not to say these springs will work at all. if you want to chop your springs, there is a way to measure how much to cut off to how much of a drop. only problem is when you hit a bump, you springs are still softer than a lowered spring and you will bottom out. lowered springs have a different spring rate for more weight, so they can take that same bump, but now allow the car to bottom out.
zzp is suppous to be making a adjustable kit for the w body,,,,
Old Jun 18, 2010 | 07:35 PM
I wouldnt trust those at all. It says they are for the 00-04?? IDK it seems like, and I think this was mentioned above, sketchy as hell. If they cant even get the years correct, I wouldnt trust them. But then again, see what their feedbakc is like, it might be good and you might have found one hell of a steal. I for sure wanna know how this all turns out, cause Im looking into this same project soon. But Im wanting to find a full bolt on kit.
Old Jun 18, 2010 | 07:36 PM
OMT, the whole honda bounce theory above is 100% correct, the weight issuse come into play when lowering a car.
Monroe
Nov 23, 2012 07:55 AM
joeykl66
Oct 10, 2012 10:08 AM
ar3em11
Mar 26, 2011 07:24 PM
mickey
Nov 22, 2005 05:31 AM
montejass
Aug 8, 2005 06:41 AM
