6th Gen ('00-'05): Gmpp sway bars?
I saw that gmpp has front and rear sway bars for our Monte Carlos and I was wondering if they are actually upgrades for the SS? Or are they just the stock bars that come on the SS's? Anyone know anything about them?
I bought the front one from gm parts direct , and it was the same as the one on my 2005 monte carlo ss supercharged...
They help with cornering keeping the car from experiencing body roll. Upgrading the bushing at the same time is good because they are better quality and the ones GM uses from factory are generally supplied by the cheapest bidder so you kinda get what you pay for lol. Here are some links to the products
Front sway bar GMPP
GMPP Front Sway Bar - Suspension & Brakes
Progress front sway bay
Progress Front Sway Bar - Suspension & Brakes
there is a difference in price but you get solid vs hollow which will help in the handling.
Poly sway bar bushings
Front Poly Sway Bar End Links - Suspension & Brakes
GMPP front sway bar end links
GMPP Front Sway Bar End Links - Suspension & Brakes
GMPP Rear sway bar
GMPP Rear Sway Bar - Suspension & Brakes
Now throw this in with the front and rear sway bar and your car will handle like it's on rails
ZZP Rear Strut Tower Braces - Suspension & Brakes
you can also upgrade the rear trailing arms but at some point you have to ask yourself what exactly are you using your car for lol
each link will give you some information on the specific product so it will help you determine exactly what will give you the best useable performance upgrade for your car and driving needs. Most factory sway bars on our cars eventually rust out and break so at that point you may as well upgrade anyways but it's all up to the driver and what they want from their car
Front sway bar GMPP
GMPP Rear sway bar
If you want stb's and trailing arms etc just buy the bmr kit as they are the best of the best.
I agree the sway bars need new poly end links but they also need poly bushings to fully take advantage of them.
