GM performance handling package
Old May 12, 2010 | 11:44 AM
Driveshaft's Avatar
Default GM performance handling package
GM parts direct has a performance handling package for $135.20. It includes front and rear heavy duty sway bars and a strut bar. Has anyone ordered this? How did it work?
Old May 12, 2010 | 11:53 AM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
yes, except I ordered mine seperately to get the rear Comp G bar, but this was years ago and I know they have changed the package.
I have the front and rear sways, STB front and back, and trailing arms and it changed the car significantly!!! Well worth the money
Old May 12, 2010 | 12:10 PM
RickAKATed10's Avatar
Photobucket
Link please.
Old May 12, 2010 | 02:00 PM
Driveshaft's Avatar
Old May 12, 2010 | 02:03 PM
Driveshaft's Avatar
I'm assuming the strut tower braces are the same for the front and rear? What trailing arms did you get and from where?
Old May 12, 2010 | 02:52 PM
Photobucket
I did some searching and I guess it doesn't work on the 2006+ models.
Old May 12, 2010 | 04:15 PM
Donutboy97's Avatar
Yes, you install the STB in the rear i just used the furthest back bolt (if looking into the trunk) and used only one of the two holes on each side of the STB to install it. The holes just need to be inlarged. Thats the cheapest way to install it. You can get brackets to install it, or drill the holes in the strut tower.
From that I have heared the trailing arms are disontinued, but this was the part number that I used... 12498649
this is apearently the GXP Trailing arms 15856683 which should work. I believe they are a boxed tubeular which would still be a better than stock application
Old May 12, 2010 | 05:52 PM
mak330's Avatar
really, i know the stbs will work if you want to drill, if you dont want to drill then they make brackets for them.
i heard they do fit, but i havent talked to a dealer. i thought most suspension parts were the same from 2000-07
Old Jun 1, 2010 | 10:06 PM
jc83's Avatar
im gonna upgrade my 2002 LS to fe4 suspension specs ..i bought 4 struts assemblies from one of the guys on this site.. i got trailing arms from MORAD..now im reading that the power steering rack is different too. LS vs. SS...do u know what the difference may be.. quicker steering ratio ??? dam just one more thing to buy !!
Old Jun 4, 2010 | 01:42 PM
Pure2sin's Avatar
Something important that I don't think that everyone knows about the GMPP kit. The FRONT sway bar is thicker, BUT it's still HALLOW. What I did was buy the rear GMPP car because it's solid, then I bought the front sway bar from Dorman because its a solid bar. I used my own poly end links in the front and it works great.
montes my python
Dec 31, 2018 04:12 PM
2005ssmonte
Jun 23, 2012 10:25 AM
hawks8
May 31, 2008 07:12 PM
montes my python
May 31, 2008 06:42 PM
IffyG
Apr 29, 2007 10:54 PM
