Special handling package
Old May 2, 2008 | 08:25 PM
montes my python's Avatar
Default Special handling package
I have an 04 SS Intimidator and want to upgrade the struts and springs
I found a great price on KYB AGX adjustable struts and an Eibach pro kit
but they are for all except when equipped with "Special handling package"
Are all Intimidators equipped with this suspension , if not, how can I tell?
The car handles well but too soft. Anybody have any ideas? Any help
would be appreciated
Thanks
Aaron
[IMG]local://upfiles/3865/1BBC1D0F8BC9419D9C4A4175BB999A9B.jpg[/IMG]
Old May 11, 2008 | 07:03 PM
Default RE: Special handling package
Com'on guys, someone out there had to have changed the struts on their Intimidator
do the aftermarket struts fit these cars or do I have to go to the stealership for struts
that still won't handle great
Thanks
Aaron
Old May 11, 2008 | 07:20 PM
Nocturnx's Avatar
I am wondering the same thing. Do the Intimidators already have an upgraded suspension?
Old May 14, 2008 | 08:26 PM
I believe all Intimidators came with the special handling package
you can check on the drivers door build tag for the FE4 suspension code
FE2 would be the standard suspension
I believe the FE4 comes with the tubular trailing arms but not sure what
the differences on the springs and struts are
The anti roll bars are also larger but not sure of the diameters (the front may be hollow)
Aaron
Old May 15, 2008 | 07:11 PM
OK, Just got an E-mail from the W Body Store, they say that the suspension parts, spring, struts
sway bars etc., are the same size for fitment, the difference is valving, spring rates etc,
which are the things we want to change anyway, so it's off to the toy store
Aaron
Old Jun 29, 2008 | 02:36 PM
bfurches's Avatar
if you dont mind sharing, where did you find a good deal? Thanks.
Old Jun 29, 2008 | 06:40 PM
On E Bay from seller name jdmwers13
http://stores.ebay.com/jdmwerks13 is his store link
Old Jul 27, 2008 | 08:03 PM
OK finally got the AGX struts, Eibach lowering springs and all the kyb mounting bits, got it installed, and aligned, what a difference in handling, just cant wait till GMPP finally ships the handling upgrade kit. Still rides good too. so far so good, and the parts do fit the cars with spec. handling package
Aaron
Old May 16, 2016 | 07:43 AM
trunks74's Avatar
Hello,
Im looking to do some suspension work on my car as well and I have the intimidator. I was wondering how much lower the car was after installing the lowering springs.
Old Oct 21, 2018 | 06:38 PM
jjs777_fzr's Avatar
Trunks74 did you ever do any of the suspension work to your Intimidator?
