fourth gen offsets and back spacing
Old Aug 3, 2010 | 10:11 AM
Buknasty's Avatar
Default fourth gen offsets and back spacing
I found this handy guide while choosing new wheels/tires for my monte. Enjoy!
It is important to note the stock bolt pattern as well, it is "5 on 4 3/4". stock = 215/65 on 15x7 front and rear Front tire/wheel:
Both the 83-85' and 86-88' style stock wheels had:
  • 3mm negative offset
  • 3 3/4" of rear backspacing
  • circle bolt pattern of 5 X 4 3/4 inches (5x120.7mm)
225/60 on 15x7 (stock wheel)
235/60 on 15x7 (stock wheel)
235/60 on 15x7 (offset: 6mm)
235/55 on 16x8 (4" backspacing)
245/50 on 16x8 (4" backspacing) Rear tire/wheel:
245/60 on 15x7 (stock wheel)
255/60 on 15x7 (stock wheel)
255/60 on 15x8 (offset: 19mm)
255/50 on 16x8 (4" backspacing) 235/60 R15 on 15x7 is by far the most popular size for all four corners.
TireWidth (inches)Height (inches) 195/60 R147.6723.21 215/65 R158.4626.00 225/50 R158.8523.85 225/60 R158.8525.62 235/60 R159.2526.10 245/60 R159.6426.57 255/60 R1510.0327.04 275/50 R1510.8225.82 235/55 R169.2526.17 245/50 R169.6425.64 255/50 R1610.0326.03 255/40 R1710.0325.03
  • Speed at 1800 RPM with 3.73 rear, 26.00 inch tires and 0.67 top gear: 55 mph
  • Speed at 1800 RPM with 3.73 rear, 25.62 inch tires and 0.67 top gear: 54 mph
  • Speed at 1800 RPM with 3.73 rear, 26.10 inch tires and 0.67 top gear: 55 mph
  • Speed at 1800 RPM with 3.73 rear, 26.57 inch tires and 0.67 top gear: 56 mph
  • Speed at 1800 RPM with 3.73 rear, 27.04 inch tires and 0.67 top gear: 57 mph
  • Speed at 1800 RPM with 3.73 rear, 25.82 inch tires and 0.67 top gear: 55 mph
  • Speed at 1800 RPM with 3.73 rear, 26.17 inch tires and 0.67 top gear: 56 mph
  • Speed at 1800 RPM with 3.73 rear, 25.64 inch tires and 0.67 top gear: 54 mph
  • Speed at 1800 RPM with 3.73 rear, 26.03 inch tires and 0.67 top gear: 55 mph
  • Speed at 1800 RPM with 3.73 rear, 25.03 inch tires and 0.67 top gear: 53 mph
Dubstepticon
May 17, 2013 10:19 AM
matrx10503
Dec 6, 2011 11:11 PM
skylark65
Feb 21, 2010 12:55 AM
TheMonteCarloKid
Feb 6, 2010 04:11 PM
jerkstore83
Nov 18, 2008 07:03 AM
