flat tire? or bigger problem?
Old Jan 9, 2010 | 10:37 PM
mrl390's Avatar
Its not as bad as I was picturing. Alot of it seems to be sheetmetal damage. The rail may have been damaged in the accident as well, but it doesnt look like it took TOO hard of a hit. The suspension doesnt seem like it took too much of a hit either, but if the rail was pushed back at all it could have affected your suspension geometry. Did they do an alignment on the car after the work was done? If not, a front end alignment might help with the leaning you described. At the very least it would let you know if your car is within spec or not. Thats if they didnt do an alignment already. If they did and they got everything within spec then I dont know what to tell you. I dont know what the sound you are describing is either, or whether it was caused by the accident or is unrelated.
Old Jan 10, 2010 | 12:18 AM
Budsjlm's Avatar
i can't belive this hasn't been brought up ... sounds kind of like a cv axle to me
Old Jan 10, 2010 | 12:21 AM
cv joint??
Old Jan 11, 2010 | 02:18 PM
werewolf-odst's Avatar
that is what it migth be, because my mom car does the same thing, the wheel shifting thing, but her car has not been in accidents. i hope it is just the alighnment. if not i will check the suspesion at a shop. thz.
oh, yea the sheet metalthing is what the guy at the shop said also,
Old Jan 11, 2010 | 02:21 PM
cv axle? is that located under the car, between the susension, and is bolted to the sub frame of the car to keep the suspension in place?
Old Jan 11, 2010 | 02:42 PM
wiz kidd's Avatar
you said when you turn left the noise goes away, that means the hub and possibly the the c.v shaft is gone on the right hand side.
the frames on these car's bend very easily, so if it was hit pretty decently you can pretty much guarentee there's frame damage, did the air bags go off??
i would look into control arms, c.v shafts and hubs, and frame damage
Old Jan 11, 2010 | 08:11 PM
when i make a soft turn to the rigth the "rooooommmm" type noise gets louder, but as i drift or turn to the left the the sounds subsides.
where exactly is the cv shaft located? somewhere in the wheel well?? no, the airbags did not go off, i just hit the sign and the car bounced over it. and i beleive i know where the control arms are.
Old Jan 11, 2010 | 09:28 PM
mrl390's Avatar
The CV joint is on the axel. The axel is what transfers power from the transmission to each wheel. The CV joint will have a rubber boot over it and will be a little bigger than your fist.
Old Jan 11, 2010 | 10:45 PM
wiz kidd's Avatar
ok, if you take your wheel off you will see your brakes, if you take the rotors off you will see the hub (will have 5 bolts sticking out, thats the hub) if you take the center nut off that, and slide that off, what you slide the hub off of is the cv shaft, the joints themselves in the cv shaft will have boots over them, if you take the cv shaft out and it feels slopy when it moves around its no good, they do go on these cars sometimes, not as often as hubs. but if your saying the noise goes away when you go left it means its your righthand side hub that is causing the problem, and from the noise your describing it sounds like a hub, if it was a cv shaft it would be there constantly, it would not go away
if its hubs that are causing the problem they're not that big of a deal, i know what they're worth in canada, i would only assume they're cheaper in the states, but up here you can get a top of the line one for about 160ish and a whitebox (offshore) one for around 100
hopefully this helps
Old Jan 12, 2010 | 12:05 AM
yeah to me it deff sounds like its somewhere in your suspension & id deff start at the cv & all that & the cradle that holds everything together is aluminum so wouldnt be hard to mess it up in an accident
