Dubs and Above 20,22,24,26,28
Old Sep 29, 2012 | 05:59 PM
  #981
Originally Posted by Mr Grizzly Mint
Mike has his dropped low.
Mike is stock in the rear
He has ebay springs up front I believe
Old Sep 29, 2012 | 06:05 PM
  #982
You would be correct & idk but when i have 2 ppl in the back & i hit a small bump it rubs lol
Old Sep 29, 2012 | 06:43 PM
  #983
Mr Grizzly Mint's Avatar
my monte sits at least 3 inches higher on 17s it seems.
Old Oct 14, 2012 | 08:48 PM
  #984
YelloJac's Avatar
From: Garfield, New Jersey. But my Home will always be The Bronx
Default Big Wheels
Ok so my ride came with 22"s all around (P245/30 - R22). OEM rims where not available. Just put new tires all around. Have no mods to the front end and no ribbing on the fenders, wheel Wells or lower strut spring bracket. The rear is a different story. First thing is, the struts are 75% Done! The last guy to own her banged in the lower strut spring bracket, bent it up, to get the wheels in. Then he used spring separators to give a 2" lift so the quarter panels wouldn't rub on big dips or speed bumps. That no work so good with 25% struts! And I know the condition of the struts is a big part of the problem. I can get new struts, a complete assembly w/ springs. But then the wheels will not mount cause the bracket isn't modified. I don't want to Bend anything on a new set of struts! I need struts with 15" between the center of the rims and the lower bracket. That would not only give the wheels the clearance they need, but keep the 2" of lift that gives her the forward motion look that I love. Does anyone know of anyplace that would make or Professionally modify a strut to work with my combo.
Old Oct 16, 2012 | 07:56 PM
  #985
Jokers1995's Avatar
I just banged my rear strut too. Not a whole lot but I did some. But that didn't work. So I measured how mic it rubbed in my rear tire and I ordered 1.25" hub centric spacers. They will be here by Friday and rims will be on Saturday. That's the cheapest way to make 22's fit. Mine are 255/30/22.
Old Oct 16, 2012 | 11:13 PM
  #986
YelloJac's Avatar
Default Twins, Almost!
JOKERS, we almost have the same ride! If I ever figure out a way to extend the rear struts, I without damaging it. I'll be sure to let you know. Where did you get your Hubcentric spacer and do the make a 2" or at least a 1.75" I can get the quarter panel rolled for $300
Old Oct 17, 2012 | 08:02 AM
  #987
Jokers1995's Avatar
I got them off of eBay. Check there for the size you need. And is getting mr quarter panels rolled necessary? And what does it look like when they get rolled? I kinda want to get my fenders flared. I think it looks good and it give you more clearance.
Old Oct 17, 2012 | 08:36 AM
  #988
Jokers1995's Avatar
Well I just looked them up. You can get 4 of the 2" spacers for 115. Or 2 of them for 65.
Old Oct 19, 2012 | 07:41 AM
  #989
Boxman420's Avatar
Fender rolling is nice incase you hit a bump you dont want the ridged edge of the fender to scrape the tire.. But paying 300 to roll your fenders is ungodly... Id pay no more thn 70$ for the back..
Old Oct 19, 2012 | 07:53 AM
  #990
Hiroska's Avatar
Anyone tried going outta town in 22s? Lol
