7th Gen ('06-'07): Dodge Charger wheels on Monte Carlo
Im curious if anyone has tried the 20" Dodge wheels on their Monte Carlo's? I think the 20" chrome 5 spoke rims would look real good. They are almost identical to the 20" camaro wheels. I know dodge uses a bigger tire, but if were to get the wheels and use a 245/35/20 I dont see why they wouldnt work since the bolt pattern is 5x115.
I just did a quick ebay search and found an outfit selling new charger oem replica wheels, just for instance these wheels are 20x9the +20mm offset and the back spacing is 5.79" is that too much back spacing?
Correct. I havent done much research yet, but I found a seller on ebay saying his oem charger rim was a 20x8. I would think a 20x8 should fit just fine even is the backspacing is high. Can anyone tell me the offset and backspacing of a factory 06-07 Monte SS rim?
They made AWD Chargers, 300C and Magnum, the 20x8 rims are AWD rims the 20x9 rims are RWD the RWD has a 20mm offset, factory monte has 40mm on an 8" wide rim and the AWD rims have a 47mm offset, so those might work with a spacer, and you dont want a rim to stick out past the fender cuz if you hit a bump ull shove it right into the fender
Heres some AWD rims
20" AWD Black Machined Dodge Charger SRT8 Magnum 300C Wheels Rims Set | eBay
Heres some AWD rims
