It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!
Old May 11, 2010 | 11:33 AM
rgant_19's Avatar
Question It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!
I was checking my brake pads because the rotors had minor rough streaks on it (to the touch). While doing so, I was wondering why my rotors were uneven and the brake pads didn't even wear down. I took a look a lil bit further and seen THIS: The first photo on the left.
Now I do not know know what part that is but the fact it is broke is what puzzlin me. I have been driving around and around not knowing why my front end was shaking while I brake from moderate to high speeds. Now, I know I need to replace that part ASAP but I just dont know what it is. While checking the brakes, the bolt that holds the caliper (on the passenger side) had broken while taking it off. What luck am I having.....lol. Its good that I seen the problem before It had gotten worse. If anyone can suggest any advice or know how, I will gladly appreciate it....
Attached Thumbnails It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!-photo0525.jpg   It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!-photo0516.jpg   It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!-photo0517.jpg   It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!-photo0519.jpg
Last edited by Space; May 11, 2010 at 02:39 PM. Reason: Add more details! & Words 2 get ATTention : )
Old May 11, 2010 | 02:09 PM
http://www.horsepowerfreaks.com/perf...et/Monte_Carlo
Click link & once connected, go to brake & supension Section
Review Parts..
Hi `Ronnie,
Above are a few pic's to check `out until one of our
Expert Tech Member's makes a post to assist/help.
Good Luck & Safe Stopping.
Old May 11, 2010 | 02:48 PM
Hi Ronnie,
Below is your homework assignment for 2day, or something to read until one of our Expert Member's makes a post
Oh, there will be a test later on the below
Knowledge is STOPPING `Power : )
p.s. I also need to review the below infor : )
How to Replace Brake Pads and Rotors Front Wheel Drive Cars
To install the new brake pads you must retract the brake caliper piston. ... How Do I Repair My Car? / How Do Replace My Front Brake Pads and Rotors? ...
www.2carpros.com/how_to/how_to_replace_brakes.htm - Cached - Similar
How to Replace Rear Brake Shoes and Drums?
About half of all car manufacturers still use drum style rear brakes. Drum brakes are not as efficient ... How do I change my front brake pads and rotors? ...
www.2carpros.com/how_to/rear_brake_shoes.htm - Cached - Similar
Show more results from www.2carpros.com
Brakes - Brake Pad Replacement - Replacing Your Brake Pads
You'll be taking the wheel off so be sure you have your car jacked up and resting securely ... Remove the Old Brake Pads · Compress the Brake Piston · Re-Install the Brake Caliper ... How To Replace Rear Brake Pads and Rotors - Replacing Rear Brakes Discs and. ... My Blog · My Forum. Explore Auto Repair. Must Reads ...
autorepair.about.com/od/fixityourself/ss/brakepadreplace.htm - Cached
Videos for How to install brakes on my car ?
When Should I Replace My Brake Pads?
1 min 16 sec - Sep 16, 2008
www.ehow.com
How to Install Car Brakes : How to Inspect ...
1 min 27 sec - Nov 19, 2007
www.youtube.com
Easy, Illustrated Instructions on How to Change Brake Pads
The first time I changed my brakes I learned two valuable lessons. First, if you are going to be working under your car, make sure you have sturdy jack ...
www.cockeyed.com/.../brakeshoes/brakeshoes_feedback.shtml - Cached - Similar
How to Change The Brake Pads in Your Car - wikiHow
Feb 25, 2010 ... Get the correct brake pads - Pads are available at any auto parts store or your local car dealership. Just let them know the year, ...
www.wikihow.com/Change-The-Brake-Pads-in-Your-Car - Cached - Similar
YouTube - How to Replace Front Brake Pads : Compressing Caliper ...
I know its a small accomplishment for some but for my mechanically challenged *** it .... queueHow to Install Car Brakes : How to Install Brak...52809 views ...
www.youtube.com/watch?v=xOkbcAdw0Es - Cached - Similar
How to Replace Brakes - Brake Pads and Rotors - MonkeySee
Winterize a Car - Brakes / ABS. In this video series, .... Richard Cottingham: My name is Richard Cottingham from Tysons Auto Specialties here in Tysons ...
www.monkeysee.com/.../11914-how-to-replace-brakes-brake-pads-and-rotors - Cached - Similar
How to Install Car Brakes: Video Series | eHow Videos
Save money and time by repairing or changing your car brakes by yourself. ... Articles. HOME; HOW TOs · VIDEOS; SHARE; COMMUNITY; MY PROFILE ... Working on your car brakes? Learn how to install brake pads with expert auto maintenance ...
www.ehow.com › ... › Auto RepairDo It Yourself Auto Repair - Cached - Similar
Brake job
Aug 22, 2006 ... How to replace the pads on your car's disc brakes. ... I did'nt think I could do the brakes on my grandma's 2000 escort zx2 cuz im used to ...
www.instructables.com/id/Brake-job/ - Cached - Similar
Old May 11, 2010 | 06:11 PM
rgant_19's Avatar
Hey KidSpace, I really appreciate the help you have provided for the DIY job. I know I will have to replace the caliper one day (just that rough dirty look is not whats happenin...lol), I can't complain because so far it is getting me around. The problem I am having is with the first photo on that part that is broken. Now I also added the rotor pics up there to show that my rotors are unbalanced (meaning, rough streaks on the rotor). By looking at that broken part today, I am sure that the reason why my front rotors are experiencing rough surfaces is because of that part. I do not know what that part is. But, I really do thank you for the extra info on how to change brakes and rotors. What I think I know, I don't know because there is always something else to get the job done.
Attached Thumbnails It Broke-Can't STOP-Need HELP ~> PLEASE - Pictures of Prob !!-broken-piece-my-car.jpg
Old May 11, 2010 | 08:03 PM
dustpusher's Avatar
That is a sway bar end link.They are only about 10 or 15 bucks
Old May 11, 2010 | 08:17 PM
mak330's Avatar
first off when you get shaking from hitting your brakes at 60 then its your rotors. take them to napa or your local machine shop to see if they can turn them.
check your brake fluid, it seems to me that your calipers may be sticking. or you use them violently a lotl.
broken should make your feel bumps more and give you a vibrating steering wheel on the highway. i know they are cheap to replace. ive had mine done already, not sure what causes it though. my roads are horrible.
sidenote:whenyour working on your car try not to wear dockers.
Old May 11, 2010 | 10:55 PM
rgant_19's Avatar
@ dustpusher: Thanks for the headz up. From what I am seeing now on the net (trying to buy it), I think the sway bar repair kit is needed instead of the bar itself. I am also trying to find instructions on how to repair it but not even the Haynes Repair Book helping me....
@ mak330: Your right, the rotors does need to be turned. The thing is, what about the used (good) brake pads that was on the rotors? I do think the calipers need to be replaced with new ones. Thats no question about that.
Also, chicago roads are not the easy roads to drive on (smh)....
Old May 11, 2010 | 11:04 PM
you shouldn't need new calipers, maybe a rebuild kit for them!
Old May 11, 2010 | 11:15 PM
rgant_19's Avatar
I haven't had no problems while braking with the calipers doing their job but I guess thats why I still have the "Red" brake light on my dash and uneven front rotors huh...
Old May 12, 2010 | 04:36 AM
Hi Ronnie, your Welcomed 4-Sure.
Thanks member's for your posts/infor to help a
family member.
`Ronnie, hope you get it fixed, and can STOP when
you need 2 and want 2 : )
Peace/Happy ~>Out
