Brake system upgrade..best bang for your buck
Old Jun 12, 2013 | 01:31 AM
NYGiantsfan's Avatar
Default Brake system upgrade..best bang for your buck
HEY SO IM IN NEED OF BETTER BRAKING WITH AFTER ALL MY MODS AND INCREASING SPEED LOL..
I NOTICED I MIGHT NEED TO GET THE 17" RIMS SO IM LOOKING INTO THAT
IM LOOKING TO DO THIS TOWARDS THE END OF THIS YEAR AND STARTING TO SHOP AROUND
I SEEN ZZP SELLING A PAIR for $309, (
fronts) with out the rotors, i dno any other options?
Old Jun 12, 2013 | 05:25 AM
I replaced my rubber brake line flex hoses with the Goodridge braided stainless lines, AC Delco advantage rotors (their performance rotors) and Bendix ceramic brake pads all the way around the car. I've been extremely happy with that setup, the brakes seem to work very well.
Old Jun 13, 2013 | 04:46 PM
thanks for the info i already did the ceramic brakes, rotors maybe ill do the lines for now. i just added a lot more hp with the supercharger kit and thinking about just going bigger on brakes and all of that. ill check my pm's now i keep forgetting to and the notification is barely noticeable when i log on lol.
Old Jun 13, 2013 | 07:05 PM
I put F body two piston calipers on my 2005 Monte SS.
I bought them on ebay for $75 shipped to my house..
Here's a pic. I have no problems with them..
The top one is stock monte Front pad
the bottom one is the Camaro front pad..
Old Jun 14, 2013 | 08:51 AM
I personally feel like the stock brakes can stop a car fine.
If you want to upgrade, the F-Body calipers is a good deal. You already have a 12" rotor so any 12" upgrades you might find on ZZP are because the Grand Prix has a stock 11" rotor.
Other than that, going to the 13" GXP upgrade is your best bet.
Old Jun 14, 2013 | 06:34 PM
rattler459's Avatar
What about doing the 06-07 monte dual piston fronts they are a direct bolt instead of the f-body's.
Old Jun 15, 2013 | 09:13 AM
F body calipers are direct bolt on aswell
Old Jun 15, 2013 | 09:34 AM
If I recall, doesn't the F-Body bracket need drilled/tapped before it bolts right up to the Monte steering knuckle?
Old Jun 15, 2013 | 09:39 AM
They sell shims to use the f body bolts but yeah the best way is to drill and tap, but if you went with shims its a direct bolt on
Old Jun 15, 2013 | 03:38 PM
If i can do this with out having to buy bigger rims i would do that lol
So i should search for what exactly on eBay, just f body calipers or what year camaro rather, this way i can stick with my same size rotors too rite? Awesome color on the calipers will deff do the same, i had a body shop paint a red stripe over the middle when I got her reprinted.
I need to start uploading pics of her on here lol
