A.B.S PROBLEM
Old May 2, 2007 | 06:23 PM
REDMAN's Avatar
Default A.B.S PROBLEM
i have a 2004 monte my brake pedal pumps up in down under normal braking conditions its like tha a.b.s is stuck on can you help me?
Old May 2, 2007 | 09:36 PM
2000LS's Avatar
Default RE: A.B.S PROBLEM
does it do it all the time, or once ina while? does it do it at all speeds? or just low speeds, or coming to a stop? brake or abs lights on, or ever been on?
Old May 2, 2007 | 10:07 PM
REDMAN's Avatar
yes it does it all the time and at all speeds and stoping since the problem ocured i thaught maybe it was a warped rotar so i did the front brakes butit was still there made sure every thing was really clean no shake in stering wheel. no abs light ever
Old May 2, 2007 | 10:24 PM
2000LS's Avatar
kinda stumped i guess.... any work done shortly before this happened? all tires the same size? any mods, especially tires/wheels/suspensioin?
if nothing to suspect so far i'd try getting it scanned to make sure theres no codes for the abs.
Old May 2, 2007 | 11:01 PM
REDMAN's Avatar
well i think im going to change the rear disc and see if the problem is still there and if it is i will get it scaned thanks for the reply 2000ls
Old May 3, 2007 | 12:32 PM
04 Intimidator's Avatar
I wonder if a shot sensor would cause this... maybe a sensor is reading that your tires are locking up?....
Justin Myers
Sep 19, 2012 08:23 PM
inyanalili
Apr 2, 2012 08:31 AM
