Air Ride in a G body
Old May 29, 2010 | 12:29 AM
Montecarloconvertible's Avatar
Default Air Ride in a G body
http://www.airride.com/productinfo/controlarms_cars.asp
What is an airbag or airspring?
An airbag and an airspring are the same thing spelled differently. It is a spring constructed of rubber and a high strength fabric. Numerous styles, sizes, and capacity ratings are available. The load capacity and ride height are varied by the air pressure in the airspring.
Are these airsprings durable and safe?
Our airsprings are made to our specs by Firestone, the world's largest airspring manufacturer. They are used on large semi-trucks, off road equipment, luxury cars, and also in industrial machinery, conveyer systems, and load stabilizers. We recently sold an airspring to replace a unit that had been in service for 17 years! (The endplate had rusted out!) Failure can happen, but it is extremely rare. We require that the vehicle have at least 2" of ground clearance when the airspring is fully deflated. This helps prevent a major problem in case of a system failure.
How much ride height adjustment will I have?
Depending on the weight of the vehicle, suspension type, and airspring selection, usually 4" to 5" in the front and 5" to 6" in the rear. We typically set an airbag suspension to ride within 2" of the stock ride height.
How long does it take to raise the ride height?
Again it depends on several factors. A 4 way RidePro™ system can be as quick as two seconds, a BigRed™ MAX system can raise your car in under one second!
What about varying loads such as people, luggage, trailer, etc?
No problem. Simply increase the air pressure until the ride height and ride quality are satisfactory. When the load is removed, release the air pressure to restore your ride height.
How is the ride quality?
Wonderful! If you closed your eyes, you would swear that you were in a new luxury car. The ride quality is also adjustable to your taste from inside the vehicle. (Try that with a coilover or leaf spring!)
How difficult is the installation?
This varies greatly from vehicle to vehicle. Most installations can be accomplished with a bare minimum of fabrication. (Some are even bolt-on.) Two guys with a little equipment should be able to install the system in a weekend.
Do you make a system for my car?
We are in continual development of new systems. If we don't make a system for your specific vehicle, we can probably assist you in adapting one of our present systems. There are very few vehicles that are not compatible with an air ride suspension.
What happens to the front wheel alignment?
The vehicle is aligned at ride height. That is the height that you want the car to go down the highway. Take note of the air pressure at this point. Whenever the system is returned to this pressure, your ride height and alignment return also.
Can I drive the car 'slammed' with no air in the airsprings?
Yes, but the ride quality is zero. You'll probably want to reserve this for parking and fairgrounds cruising. It won't hurt the airsprings, but it may hurt your back! Caution: If you are going to drive the car 'slammed', pay very close attention to ground clearance and tire clearance. There is a lot of difference between laying the oil pan on the ground and dragging it on the ground!
78-88 GM "G" Body Front and Rear
Description Part # Price
78-88 GM “G” body COOLRIDE kit with Lower StrongArms ARF11100-LCA $699.00
78-88 GM “G” body COOLRIDE kit with Upper and Lower StrongArms ARF11100-LUCA $899.00
78-88 GM “G” body COOLRIDE Lower StrongArms LCA11100 $329.00
1 Pair
78-88 GM “G” body COOLRIDE Upper and Lower StrongArms LUCA11100 $629.00
1 Pair
78-88 GM “G” body Single Adjustable SHOCKWAVE kit with Lower StrongArms SKW1034SA-LCA $999.00
78-88 GM “G” body Double Adjustable SHOCKWAVE kit with Lower StrongArms SKW1034DA-LCA $1,269.00
78-88 GM “G” body Single Adjustable SHOCKWAVE kit with Upper and Lower StrongArms SKW1034SA-LUCA $1,499.00
78-88 GM “G” body Double Adjustable SHOCKWAVE kit with Upper and Lower StrongArms SKW1034DA-LUCA $1,469.00
78-88 GM “G” body SHOCKWAVE Lower StrongArms LCA1034 $329.00
78-88 GM “G” body SHOCKWAVE Upper and Lower StrongArms LUCA1034 $629.00
78-88 GM “G” body Upper StrongArms UCA1034 $329.00
78-88 GM “G” body COOLRIDE REAR Kit with Upper and Lower StrongArms ARR21100-LUCA $749.00
78-88 GM "G" Body Rear Upper and Lower StrongArms LUCA21100 $429.00
Old Jun 7, 2010 | 09:14 PM
jc83's Avatar
been looking for an airbag/spring system just to boost my montes rearend when i pack the trunk full of camping equipment ...gets heavy & turns into a low rider !!...anybody try doing this ??? i am curious if it can be done to a monte... i dont remember seeing a good place underneath to mount an airbag to ..
Old Jun 16, 2010 | 11:15 PM
brokensmile3800's Avatar
I got a 2000 monte carlo ss!!! Can I put air ride on it?
Dec 29, 2011 06:05 PM
chitownmc
Nov 13, 2010 03:55 AM
Draciel
Sep 13, 2009 01:25 PM
sweetmonte01
Jan 18, 2006 09:00 PM
sweetmonte01
Jan 8, 2006 10:33 PM
