3800-3400 Suspension Compatibility
Old Mar 22, 2021 | 10:33 PM
ThunderSlug's Avatar
Default 3800-3400 Suspension Compatibility
Could someone tell me if this product (designed for the 3800 Montes) would fit on my 3400?
Link: https://zzperformance.com/collection...12623169454191
I contacted ZZP and they told be they didn't test it on the 3400s, but they think it would probably work. I just want to be sure.
TIA
Old Mar 23, 2021 | 07:21 AM
Yea, theyll fit. At that price point, why not just spend the couple hundred more for coilovers?
Old Mar 23, 2021 | 09:27 AM
IMO I struggle with them calling the GR2 struts a performance option. They may not be as soft as some stock W body struts, but they're still way over on the comfort side of things. The only people who will see a performance improvement are those who are replacing literal blown struts.
As noted above with the AGX option, youre pretty close to coilovers at that point anyways.
Old Mar 23, 2021 | 11:28 AM
To be honest, even these were more than I wanted to spend, but I've seen that people say not to get only lowering springs without struts/shocks. I'm really on a budget for this mod. If I did just install the springs, how long do you think it would be before the stock struts/shocks wear out? I'm not sure if it's worth it. My monte has 125k miles on it.
Old Mar 23, 2021 | 02:20 PM
If your shocks are ok you could get by with just lowering springs. Im preparing to do that in the next couple days, they literally JUST got delivered. Ive done it in the past also and it was fine, it was just much lower than it should have been.
Old Mar 23, 2021 | 02:26 PM
Old Mar 23, 2021 | 02:34 PM
Are those still original struts? If so, they're due for replacement anyways. I wouoldnt go through all the effort to install springs and not replace struts with that kind of mileage.
The other thing to keep in mind is that lowering springs tend to be harder on struts in general. The more drop, usually the worse strut life. Im not familiar with the zzp springs, but in general I would always suggest holding off on doing the job until you can afford to do both at once.
Old Mar 23, 2021 | 05:19 PM
Thanks for the tips everyone! I'm gonna have to look back into this car's history to see if the struts/shocks were ever replaced before I owned it. If not, then I agree that I should just get it all at once.
Old Mar 25, 2021 | 09:24 PM
Steelbizkit's Avatar
i look at it as "do it once not twice." if your gonna have the struts apart to install new springs might as well swap out the wear items (i.e. struts, strut mounts and bellows).
then you dont have to worry bout it for years.
Thrush_Glasspack
Feb 27, 2020 08:01 AM
Hydra
Nov 8, 2010 08:27 AM
superrod29
Mar 27, 2010 01:18 AM
wht02monte
Mar 5, 2010 07:14 PM
85MCSS
Sep 18, 2008 08:09 AM
