22's Flush
Old Jun 9, 2008 | 07:40 PM
chevyrider08's Avatar
Default 22's Flush
Someone please help me figure out a way 2 tuck my 22's in the back flush...they have these enourmous spacers...which pokes the back out bout 1 1/2 inch...each side...i have a 255/30...n the rim is 22 X 8.5....so if any1 has an idea let me kno...THANKZ
Old Jun 10, 2008 | 09:31 PM
wheelguy's Avatar
Default RE: 22's Flush
ORIGINAL: chevyrider08
I assume you have a front wheel drive car & the wheels aren't 5x115 or 114.3 other wise you wouldn't need the adapters you are using. If that's the case you can buy 1" adapters & get rid of the thicker ones but that will only pull them in a little. If the wheels have the correct pcd then just pound up the plates on the struts & you're good to go.
Old Jun 10, 2008 | 10:25 PM
no they are the correct bolt pattern...its just wit out the i guess i should call them spacers...it would lik press on the back strut alot...i tryed beatin the back plate but it only goes in...and not up which i needed it 2...do u kno a site wit spacer that dont need 2 be bolted on lik the ones i have...but r thick enough to clear the strut?
Old Jun 11, 2008 | 05:55 PM
mickey's Avatar
the only thing i know of to change this is to change the back space on the wheels and or to get rid of the spacers on them so they will fit in there.
but if your hitting anyway then there is only one choice and that is change the back spaceing. or i guess you might beabel to talk with someone and see if you can cut or grind the parts that you hit on in there with out hurting anything
Old Jun 14, 2008 | 05:50 PM
SolowSS's Avatar
Just call me Dubs
I have 22x8.5 with a 255/30/22 tire and I had no problems getting them on nor do I have spacers in the back my wheels don't even stick out
Old Jun 15, 2008 | 01:07 AM
maybe the offset has alot 2 do wit it...but damn ive tryed to put them in wit spacers...n it just wont happen...u think u can give me some pics?...hit me back up
Old Jul 1, 2008 | 10:28 PM
SolowSS's Avatar
Just call me Dubs
here's some
[IMG]local://upfiles/3347/3D925AC8B4064081BA8F81CF6A819ED7.jpg[/IMG]
[IMG]local://upfiles/3347/F100A68248F8446FBAAEF795216970C7.jpg[/IMG]
[IMG]local://upfiles/3347/27EE87FF26624089B076EE999646CE11.jpg[/IMG]
[IMG]local://upfiles/3347/9B9AB09512774D20BFA5E78F35BF08CC.jpg[/IMG]
Old Jul 8, 2008 | 12:25 PM
blackice's Avatar
Default RE: 22'
You got the wrong size tires.. i have 22x8.5 and spacers and mine dont stick out but i have 235/30/22 tires
Old Apr 24, 2010 | 10:52 PM
04MonteLS's Avatar
you have the wrong offset, you'd need to buy a new set of rims
Old Apr 25, 2010 | 09:58 AM
mrl390's Avatar
Can you say 2 year old thread?
