225/60 to 245/55 will it work?
Old Jan 10, 2010 | 09:40 PM
JaxJim's Avatar
Default 225/60 to 245/55 will it work?
Anyone out there go up from a 225/60/16 to a 245/55/16 and did it work? My car's a 1999 Z34, and I know that GM had to increase the turning radius on these cars just to get the 225/60's to fit, so I'm thinking there's probably not much room for a 245. Figured I'd ask though.
Old Jan 10, 2010 | 11:27 PM
it will fit but its going to rub, not sure how much room youll have to turn until it will rub tho
Old Jan 11, 2010 | 12:55 AM
Enzo354's Avatar
STILL SLOW
245 (55!!!!) do you have a pickup???
Old Jan 11, 2010 | 08:23 AM
MAMONTE's Avatar
I would not do that. I think A) its a little on the wide side for that car. B) a 55 tire on a 16" wheel will not fill up your wheel well enough, and it will look weird.
Old Jan 11, 2010 | 08:44 AM
JaxJim's Avatar
Probably is too wide, however the sidewall of a 245/55 would be the same as a 225/60. 225 x .60 = 135. 245 x .55 = 134.75. The aspect ratio (the 55) is how tall the sidewall is in comparision to the width of the tread.
Old Jan 11, 2010 | 09:04 AM
MAMONTE's Avatar
Duh! You're completely right. I was not thinking that one all the way through. But in any event, yea, I would say you're pushing it for width. Maybe a 235 would fit though?
Old Jan 11, 2010 | 01:11 PM
JaxJim's Avatar
We've already reached the point when a bone stock, no option minivan has 225 series rubber, so the 225's on the Monte look so plain. The new Camaro comes standard with 245/55/18's. Optional from the factory are 275/40/20's. The dealer will sell you 21's if you want. Crazy.
Old Jan 11, 2010 | 01:14 PM
wiz kidd's Avatar
i'd give it a try, you should be fine unless your car is lowered, if your getting a good deal on them i'd say try em
S.O.G.
Jan 10, 2013 11:17 PM
Apr 8, 2012 01:42 AM
twfurst
Feb 21, 2012 10:13 AM
wildnorth29
Jun 18, 2009 08:26 AM
