2000 Monte Carlo SS Rims
i got the 2000 monte carlo with the stock rims and i am looking for something different..it is currently running the 225x60x16 tires on them...can someone let me know what type of rims i should be looking for...as in the rim size with the back spacing..
RE: 2000 Monte Carlo SS Rims
You can fit almost any size rim that you want from 14" - 20" (i'm sure even bigger with a drop) but it would be real difficult to run a wheel that'swider than 10". The stock wheels have an offset of about 39mm(1-1/2") (these are all taken from my '01 SS) and a backspacing of around 5"-6". The stock rims are 16x7" by the way.
This link will help you if you find wheels you like. Enter the specs in and you can find almost eveyrything you need to know about how the wheel/tire will act on the car.
http://www.rims-n-tires.com/rt_specs.jsp
7th Gen ('06-'07): 16" Monte Carlo Rims OK to use with 2006 Monte Carlo SS?
kkritislas
11-11-2014 08:14 PM
07-22-2011 09:12 PM
motivation2k3
10-24-2007 11:21 AM
2000_BLACK_SS
10-15-2006 12:24 AM
