2000 monte carlo ss with 20 inch wheels... HELP!!!
Old Jan 20, 2009 | 04:58 PM
2000_ss's Avatar
Default 2000 monte carlo ss with 20 inch wheels... HELP!!!
I have a 2000 monte carlo ss with 20 inch wheels and the back struts are rubbing my tires when i hit a bump. Is there something i might could do to fix this and if so what? Any help would be great thanks.
Old Jan 21, 2009 | 10:30 PM
02on20s's Avatar
Default RE: 2000 monte carlo ss with 20 inch wheels... HELP!!!
Your tires are rubbing on your struts???? are you sure the tires are not contacting the lip on the wheel well cuz the strut will travel with the tire and should not suddenly allow the tire to contact it.
Old Jan 22, 2009 | 09:51 AM
2000_ss's Avatar
well im not to sure really.but the inside of my tire was rubbed like where the strut would make contact. but im not really sure. wat could i do to prevent that?
Old Jan 25, 2009 | 09:41 PM
zwc0442's Avatar
What offset do you have. I have a set of 20x8.5 with a 40mm offset and I had to roll the fender lip just a little bit because they would barely rub every once and a while. Theres probably 1/2" of clearence between my strut and wheel on the rear.
Old Jan 25, 2009 | 09:56 PM
sprfrk2005's Avatar
thats very odd it shouldnt be rubbing against anythingi have 20's running a 255/35/20 tire and it still have about 1 inch of clearance and only rubs when i have people on the back and hit a bump very odd
SuperSport™
Apr 13, 2015 01:28 PM
mavrickf1613
Mar 9, 2008 02:17 PM
nix06monte
Nov 16, 2007 11:12 PM
