2000-2005 (06-07) Also, 22" Rims??
Old 12-12-2010, 03:23 PM
dezzyboi16's Avatar
Default 2000-2005 (06-07) Also, 22" Rims??
Anyone have 22" rims on their MC's? Trying to see what needs to be done, some have said nothing needed besides skinny tires, others have took different measures....Anyone?
Old 12-12-2010, 04:01 PM
22s should fit no problem with just a rubberband tire, unless your suspension is shot
Old 12-12-2010, 04:22 PM
dezzyboi16's Avatar
Ok thanks, thats what the other folks told me.
Old 12-27-2010, 02:15 AM
i have a pair of 22" dub karma's on my 07 and it fits PERFECT with skinnies. NO RUB. looks perfect they fit the wheel wells so nice, i wanted 24's and im so glad i didnt cut the car up to do that 22's is a much better choice, looks and drives much better IMO
Old 12-29-2010, 09:00 PM
dezzyboi16's Avatar
PICS!!!!
I'm debating on DUBs or some 2/3 piece rims or just some rockstarr rims I like, the dynasty 557's.
Old 01-18-2011, 06:57 PM
tire brand and size
Old 01-19-2011, 01:12 PM
dezzyboi16's Avatar
Huh?
it'll be 255/30/22s
Old 01-19-2011, 04:58 PM
can you lower your car with 20s and 255/35/20?
Old 01-19-2011, 08:43 PM
I had an 02 monte ss prior to my 06 ss. I had 245/35/20 on arelli spiga's; when i went to 255/35/20, they filled up the wheel wells nicely, but if you loaded the trunk with groceries, or had someone sitting in the back seat... You'd get an occasional rub on the rear lip of the fender. I was running goodyears. At the time they only had on 255/35/20. I think it was the hp ultra? Answer to the question... Dont lower it - (you don't need to; the 255 will give you that fullness)!
Old 01-19-2011, 08:47 PM
But on an 06 or 07 ss, you could lower it because the car sits higher because its set up for the 18s. (which mean adding a 20" rim is only a plus 2... Where as on an 02, a 20" rim is a plus 4 because it was set up for 16s).
Quick Reply: 2000-2005 (06-07) Also, 22" Rims??
