07 wheel sensors info
Old Feb 19, 2012 | 08:38 AM
Nowhere Man's Avatar
Default 07 wheel sensors info
hello I am helping my sister with a 07 LS. she wanted to get rid of her steel wheels and caps. So I found a nice set of GM alloy wheels from a 04 Impala SS. her original wheels have the metal valve steams. so can I remove them and put them on the alloy wheels to get rid of the light on the dash
Old Feb 19, 2012 | 02:54 PM
DuSSt's Avatar
As long as the wheels you now have are compatable with the valve stems from the stock rims then you can do this, certainly worth attempting if you are able to switch them out yourself.
Old Feb 19, 2012 | 03:54 PM
well the problem is both sets of wheels are mounted on the wheels
Old Feb 20, 2012 | 08:24 AM
Then you'll have to go to a tire-place to have them remove the wheel, swap the sensors and remount the wheel.
jaygr
May 25, 2012 10:20 PM
davidk67
May 10, 2012 09:21 AM
pwr8311
Mar 11, 2011 12:33 AM
Greeny
Oct 30, 2006 11:50 PM
